    Aug 2013
    86
    Gearing ideas lipo 4s 10000 mah
    What do u think people what gearing do u think will be the best at this battery power it last for a long time I don't want to buy a whole heap of gearing and mes around I want to know if anyone else played around?
    HSV CLUBSPORT BUILD#330
    Alma, Michigan
    12,316
    Stock is fine for 4S... that is what it runs in stock form.
    Where are you getting 10,000mAh batteries that fit?
    Apr 2013
    Ontario, Canada
    778
    Id like to know too.
    Aug 2013
    86
    No sorry I ment 2 x 5000 mah
    Ok lowered the spur to 62 stock pinion yep much better I still have other pinions to play with so I will keep updated for those who do want to change ?
    Typed from a fisher price keyboard ! I'm still laughing at petty fools ?
    Sep 2010
    561
    With the way the EVX-2 is set up stock you're using a series connection, so 5000mah at 14.8v. Parallel would be 10,000 mah at 7.4v but this is not how Summit is wired (Unless you've done some creative wiring).
    The packs are used in series to increase voltage.
    Parallel would increase runtime but keep the voltage the same.
    Aug 2013
    86
    Yep that it yeeeewwww that gearing rips Definetly cut my battery time literally in Hal I just got a whole 20 minutes I usually get about 40 when stock gearing is used but definetly worth it i am using a 17t pinion with 62t spur and its the best basher now and crashes are a lot bigger too have not lost acceleration the Titan is a very tourqe full motor
    Jul 2013
    235
    If you like that gearing, read some Dewalt threads. You might like a Dewalt motor even more
    Brushless 19/62 SPC 8.2 It's not a Tekin or a MM
    Aug 2013
    86
    Good advice where can I get a dewalt motor today a cheap drill maybe? 29$ I think
