Results 1 to 31 of 31
    May 2013
    186
    Tire choices?????????? lost
    im in the process of putting my summit together got it as a project
    last problem is tires and trying to find pics that compare tires to the stock ones is almost imposable
    so could any one help with pics of there tires compaired to the stock 1/10th tires
    im looking at the following tires
    1. Proline Trencher x 40 series
    2. Proline Mashers 3.8
    3. RC 4WD Mud Slingers Monster Size 40
    any help would be great thanks
    Victoria B.C Canada
    5,435
    Trenchers are close ish to stock
    Trenchers next to mudslingers
    Sent using lipo power
    Mountains cant stop me
    they have tried
    5,412
    Is this what your looking for?
    Is owning 25 RC's too many?... Nope!
    May 2013
    186
    what are the risk of running slingers?
    and what rims would u put them on so they dont rub
    got a pic to show the width
    PARKER COLO
    943
    Trencher 40 series tech 5 wheels next to stock [IMG][/IMG]
    [IMG][/IMG]
    The trencher 40 series on the tech 5 wheels reduce the outside tire dimension by about 1.5 inches less wide than the stock Canyons. They are great tires and for running through tight trails and rocks they work great. they are about the same height.
    Here are some photos of the mudslingers, the front truck has the stock tires the rear has the mudslingers. [IMG][/IMG]
    Here the tires to the right are stock and the left are mudslingers. [IMG][/IMG]
    A couple photos of the truck with the Mudslingers. [IMG][/IMG]
    [IMG][/IMG]
    The Mudslingers are an inch taller at 7.5 inches vs Canyons at 6.5 inches. They are about the same width. I gear cut the foam on the Mudslingers to make them softer. They are not as soft as the Stock tires but close. I upgraded the steering servo to a Savox 1230 sg 500 oz. I put an alum steering saver on. IMO I would not run the Mudslingers without these changes. Just a matter of time till you tear it up. I love the Slingers, better ground clearance, aggressive tread, they look like they fit on the Summit, the other tires always seemed to look to small. I would give them a 5 out of 5 rating. I bought some stock geo wheels, dechromed them, cut the foams in a gear shape, glued them onto the stock geo wheels. Trust me if I can do it most every one can. Post back with more questions. I believe CROCK did a big thread on this and I placed some photos in that thread. By the way welcome to the forum, ask lots of questions very knowledgeable people here.
    "Better Old and Devious than Young and Exuberant"
    May 2013
    186
    thank you thats what i was looking for i like the look of the slingers i have the same bronco body but its modded so that helps i do have upgraded steering servos so that will help im just worried about gearing and what not what gears do u run?
    and gear cutting the foam seems like every ones doing i just bash around in the lawn and corn fields would cutting the foam help anything?
    if you had to choose whats the better set up for all around bashing trenchers or slingers?
    Saint Louis, MO
    504
    I have the stock wheels, mashers, trenchers (the 40 series), and mudslingers. I have ran them all in the same location and I think I like the trenchers best. They do well on any terrain and the tech 5 wheels have no offset so they narrow up the truck.
    You can't go wrong with any of them though.
    May 2013
    186
    ok at least im looking at good tires i dont want narrow lol
    PARKER COLO
    943
    Quote Originally Posted by speedpro22 View Post
    I would still cut the foam. I bash alot and I just really like the Slingers. The trenchers are great tires but they just are not the Slingers. I PM'd you about your gearing question. Search out CROCKS thread about "will they fit" I have a complete how to do the foams in that thread, including a template you can copy and paste, size up to the foams and cut them. I don't know if you have ever done it but its no big deal to do.
    May 2013
    186
    nope this is my first big truck all ive messed with are a rustler vxl and my old losi aftershock but thank you
    what are the advantages of cutting the foam?
    PARKER COLO
    943
    It softens the tire to allow the tire to have better traction. When you gear cut the foam it leaves some firmness but not all. Mine have been great for bashing and crawling. Cant speak to road racing I dont do it.
    PARKER COLO
    943
    Here is the link to CROCK's "Will they fit" http://traxxas.com/forums/showthread...ighlight=crock starting at post 77 is the info on cutting the foams, mounting the tires and a gear shaped template you can download and size for your foam.
    Also these Mudslingers are in fact directional, its hard to see in person but if you look at the photos you will see they have a little curve to them. So make sure you get them the right way or you can do what i did and order another set and get them all going the right way and have two sets. Its a tire thing (addiction).
    Victoria B.C Canada
    5,435
    Rock crushers not slingers...whoops
    Slingers,trenchers,crushers oh my
    they have tried
    May 2013
    186
    where did u get the bead locks ?
    and are they offset or no
    Victoria B.C Canada
    5,435
    The hard to find axial rocksters
    Had for a while.lots of offset kinda makes it look odd.after the tec 5 zero offset(Cheyenne beadlocs in the middle discontinued)
    they have tried
    May 2013
    186
    i love the middle ones anyone got them fs lol
    Victoria B.C Canada
    5,435
    See them on eBay now and then
    Pro line Cheyenne beadlocks
    they have tried
    Jul 2013
    235
    For yard bashing, I'd say go with Trencher X pre mounted on Desperados or F-11's
    Brushless 19/62 SPC 8.2 It's not a Tekin or a MM
    May 2013
    186
    i think im going with slingers the trenchers are well thats what everyone dose lol and i like the look of the slingers
    5,412
    There "may" be a reason why so many people have the Trenchers.... Either one you get will be great.
    Oct 2010
    Parsippany, NJ
    752
    I have slingers. Not a good multi purpose tire. Great for crawling around woods but awful for bashing cause they are so big and clumsy. They are also heavy so to say you're going to lose about 25% run time would be generous.
    May 2013
    186
    im thinking im gonna get slingers for trail driving in the woods and crawling and mashers for bashing
    Oct 2010
    Parsippany, NJ
    752
    Atta boy! However the regular trenchers (not the X) are awesome for bashing. Also do very well crawling. I do not have experience with the X but since they are smaller, you will lose almost .5" clearance. IMO,..trenhcer X look cooler, but the non-X "seem more" capable.
    I won't disclose my ultimate bashing tire for fear the market will meet the demand....hehehe...
    May 2013
    186
    my buddy kikilink333 is prob gonna get trenchers so i cant match his truck lol so i like the way the mashers look hopefully they preform like i hope lol
    Oct 2010
    Parsippany, NJ
    752
    People seem to like their Mashers as well. Will be fun to compete and see who the king of the dirt is Come back and post results.
    May 2013
    186
    lol its always fun when u got someone to run with we mess around with our rustlers all the time hes more how would u say um conservitive maybe im more hey lets jump the rustler off the roof and bend a shock into a 90 dagree angle lol
    Victoria B.C Canada
    5,435
    I agree to get full fun out of the truck.you need more than one.
    they have tried
    May 2013
    186
    yea next on the list is drift cars
    Aug 2013
    20
    Mickey Thompson baja claws. best all around tire. The stock Canyons are great for the summit but they balloon if got are running brushless.i also own trencher x but they are wide and slide out a lot. Mud Slingers are great in mud but not for bashing b/c they are heavy. Team losi has some cool Claw MTs too.
    May 2013
    186
    im pretty much made up my mind on slingers with bead locks and a set of pre mounted mashers on despies
    Sep 2013
    6
    I just got a set of 3.8 mashers last week so fsr there great on all terrain but not the best once the pack full of mud
