Results 41 to 80 of 120
  1. #41
    19,552
    ...According to the RX8 Gen2 manual, the T8 1700 motor is recommended for use with the RX8 on 5S. There are motors recommended for 6S, but those aren't really in this discussion so I think we can ignore those...
    Quote Originally Posted by mrhammer2u View Post
    I think he decided to go with a 1550kv. Plan on pulling a Volkswagen?
    Looks like we can't ignore these any longer: the 1550 is one of the motors for which 6S is recommended.
    Alt-248 on the number pad = °
  2. #42
    Jul 2013
    235
    FWIW:
    On stock gearing and Trencher Xs, I calculate 21.86 MPH for [that] 1700KV motor
    On stock gearing and Trenchers, I calculate 23.17 MPH for [that] 1700KV motor
    On 18/62 gearing and Trencher Xs, I calculate 30.82 MPH for [that] 1700KV motor
    On 18/62 gearing and Trenchers, I calculate 32.67 MPH for [that] 1700KV motor
    As for 18/62 being too high gearing, I've run 21/62 in my ERBE (2200kv) for a long, long time with HPI Terrapins as my tire of choice. This is actually a pretty mild setup so far as E-Revos go. The tires are 6.69" in diameter, which is just about exactly in the middle of Trencher and Trencher X tires. On 4S heat is not an issue. Why then would 18/62 with a 1700kv motor be too high?
    How? I calculated again, and I got the same result.
    Brushless 19/62 SPC 8.2 It's not a Tekin or a MM
  3. #43
    19,552
    Quote Originally Posted by Deviate View Post
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 68
    Pinion Tooth Count: 14
    Total Voltage: 16.80
    Motor KV: 1705
    Tire Diameter (inches): 6.5
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0
    Spur/Pinion Ratio: 4.86 : 1
    Total Ratio: 25.34432 : 1
    Tire Circumference (inches): 20.42 inches (518.68 mm)
    Rollout: 0.81:1
    Total Motor Speed: 28644 RPM
    Vehicle Speed: 21.86 mph (35.11 km/h)
    Effective KV Value: 1705
    KT constant: 0.79 oz-in/A
    Motor Torque: Amperage not specified...
    Final Torque: Amperage not specified...
    Final Power: Amperage not specified...
    Other Ratio: 1
    Motor KV: 1705
    Tire Diameter (inches): 6.89
    Tire Circumference (inches): 21.65 inches (549.8 mm)
    Rollout: 0.85:1
    Vehicle Speed: 23.17 mph (37.21 km/h)
  4. #44
    Apr 2013
    Ontario, Canada
    778
    Dang straight! I`ll have some feed back once I solder my 1550 up! I have 11-28t pinions... and most spurs 36-68t?, currently 18/65 I believe in my Summit with the 775, Whats a good balance point for this new system with my Summit?
  5. #45
    Princeville, Québec
    960
    Quote Originally Posted by Northern Adventurer View Post
    I'm still waiting for it to be delivered. So your feedback will be great!
    Summit RX8/1550kv-Slash4x4 MM2/2400kv Twin-V Merv.
  6. #46
    Aug 2012
    Alberta Canada
    969
    All my buddies have tekin in everything the sensored motor is sooo smooth and powerful. Its fast aswell easily keep up with a mamba and pass it, I would keep the summit geared low, to much speed will just wreck the truck, we had to turn back my cousins truck becuase he would twist everything off, its geared to go like 40mph in in 2nd and in low it has enough torque to pull me in a Wagon
    Posted by my Galaxy tab 3 8"
  7. #47
    la porte
    697
    FWIW:
    I ment high as in the gear ratio 18/62 is a higher gear ratio then what I run 18/54
    And have no heat issues here in Texas running 4/5/6s.
    Sent from my iPhone using My Thumbs
    6S OR NOTHING............................ maybe 5s
  8. #48
    19,552
    Quote Originally Posted by mydudrevo View Post
    I ment high as in the gear ration 18/62 is a higher gear ratio then what I run 18/54
    18/62 is a LOWER gear ratio than 18/54.
  9. #49
    Oct 2010
    Parsippany, NJ
    752
    Quote Originally Posted by Maxx_Adam View Post
    All my buddies have tekin in everything the sensored motor is sooo smooth and powerful. Its fast as well easily keep up with a mamba and pass it,"
    I'm going to have to put this debate to bed. Not sure the Tekin is passing the MMM easily, if at all. Wonder if my buddy has the same bullets I do to do a motor swap and find out????
  10. #50
    Jul 2013
    235
    It's nice havin a buddy with a Summit and compatible power system. If you are havin a problem, to find the culprit you can swap parts till it works.
  11. #51
    Princeville, Québec
    960
    I received, yesterday, my rx8/t8 combo... Unfortunately, i'm unable to do the soldering, the solder won't stay on... What should i do?
  12. #52
    Oct 2010
    Parsippany, NJ
    752
    Quote Originally Posted by boilo56 View Post
    Youtube is a great resource to learn to solder. Or go to LHS and pay them to do it.
  13. #53
    19,552
    Do you have a Local Hobby Shop than will do it? Or a local fellow enthusiast who can?
  14. #54
    Princeville, Québec
    960
    Well, i am in the worst situation, i just moved to this city, the hobby store is 12milles from here, and i have no car... i guess i'll have to take a cab.
  15. #55
    Apr 2013
    Ontario, Canada
    778
    Make sure you have a good soldering iron, not the cheapies that come in tool kits.
    I tried 3 cheapies before shelling out the money for a good one, then soldering became easy.
  16. #56
    Princeville, Québec
    960
    I finally made the soldering and i also put the combo in the truck! I hope everything will be ok tomorrow!
  17. #57
    Princeville, Québec
    960
    Well, tomorrow as come, but it is raining cats and dogs over here. Does anyone knows how to really waterproof the tekin rx8?
  18. #58
    Dec 2004
    PA
    4,051
    Be very careful in the rain as it would be very disappointing to ruin that new Tekin system.
  19. #59
    Princeville, Québec
    960
    Quote Originally Posted by Jakey View Post
    Believe me, that thing won't see any water until it is completelly waterproofed! I only need to find the best proven way!
  20. #60
    Dec 2004
    PA
    4,051
    Good to hear. Just would hate to see a water issue with that system after all you went through trying to decide which system was best for your use.
  21. #61
    Jul 2013
    235
    Plasti-dip might be ready by this evening. It can take a while to dry each coat. Or you can soak it in Corrosion X. There is a lot of information on those products on this forum.
  22. #62
    Princeville, Québec
    960
    I will do some Research on this, Thank you for the tip!
    Envoyé depuis mon Z10 avec Tapatalk
  23. #63
    Princeville, Québec
    960
    i got plastidip in a spray can, will it dothe same as the other?
  24. #64
    Princeville, Québec
    960
    I went with Squirrel's method for waterproofing, do you think am ok going this way? I really look forward to get the summit out for a ride!
  25. #65
    Apr 2013
    Ontario, Canada
    778
    I just finished soldering/waterproofing mine, I had both plastidip and liquid electrical tape. Decided last min to use the LET. Only need to finish sealing the sensor and fan port on the exterior.
    Man, I tell you It was a huge relief when I turned it on for the first time and it powered on successfully. As this was my first time waterproofing, I was a little worried.
    But it all went back together great and Im super stoaked.
    Cant wait for my Aluminum LEM axles and hardened diff gears to show up next week to put my Summit back together!
  26. #66
    Princeville, Québec
    960
    Did you have any problems with air bubbles around the heatsink, because mine had some tiny holes made by air bubbles. Also, mine looks exactly as yours, so i guess we are on the right track!
  27. #67
    Apr 2013
    Ontario, Canada
    778
    no, didnt really have a prob with air bubbles. I did have one I noticed, but on my second coat I made sure I took care of it.
    I used a small paint brush, maybe brushing strokes helps push out the bubbles instead of just dipping it or pouring it on.
  28. #68
    Princeville, Québec
    960
    I just did the 4th and last coat! I did just like you said, and i used a paint brush, it worked very well! Now, i'm waiting fot it to dry, and then, i'll test!
  29. #69
    Apr 2013
    Ontario, Canada
    778
    Great, let me know how it goes.
  30. #70
    Princeville, Québec
    960
    I wanted to ask you about your motor, what model is it? Mine is 1550kv, and i was wondering what gearing to put on?
  31. #71
    Apr 2013
    Ontario, Canada
    778
    Im running the 1550kv as well.
    I will be starting with stock gearing.
  32. #72
    Princeville, Québec
    960
    cool, can you tell me you toughts about the combo? I didn't run mine yet... only tested my soldering and connections, so far!
  33. #73
    Princeville, Québec
    960
    An other question, did you waterproof the sensorboard on the motor?
  34. #74
    Apr 2013
    Ontario, Canada
    778
    I wont be going into the motor. But will silicone the outside of the connection once connected.
  35. #75
    Apr 2013
    Ontario, Canada
    778
    same with fan.
  36. #76
    Princeville, Québec
    960
    I just went out to test everything... The results are very good! i ran in some puddles, slow and fast, and everything still works! i think i did it the right way!
  37. #77
    Apr 2013
    Ontario, Canada
    778
    Awesome, I wont be putting it in water on purpose. I always think less is better. I didn't waterproof mine to submerge it, just to help when it accidentally gets wet. But I am quite confident it is 99% waterproof now
    glad all is working fine. Ive only tested my system on a blank chassis for now until I rebuild my summit to make sure it works, so I'm not sure how bad to expect the temps to get with the waterproofing.
    How were your temps?
  38. #78
    Princeville, Québec
    960
    by toucg only, it was cold, as in COLD! Esc fan didn't even wanted to start!!! And if you want wheelies, then you'll be served even on stock gearing! THIS IS COOL!
  39. #79
    Apr 2013
    Ontario, Canada
    778
    Sweet, were you running 4s or 6s? and how long at what throttle for this ice cold reading?
  40. #80
    Princeville, Québec
    960
    I was running 4s, throttle time is about 45sec full, turn around and45sec. back to me, for about 3/4 battery pack(2x2s in serie)! I can't run 6s, my 2 3s 5000mah didn't came in yet. But i think i'm gonna like 6s power!
