Results 1 to 11 of 11
    Jul 2013
    5
    fried the stock titan t12
    adjusted the slipper clutch because it would squeal on slight inclines and rough surface. took it for a test run. ran amazing, good starts and no whines. took it on a packed atv trail ran 20ft turned around and got stuck in a small trench reversed out and had no forward or reverse after. smelled like burning plastic. unplugged and turned things off. motor was warm not hot, battery was cold, and esc was cool. battery had good charge left and esc was responding to trigger and wheels. no response from motor. spun both wheels to see if motor was locked, spun but rough on pinion and spur. backed clutch off one more full turn( two full turns from tight). turned rc on, got the motor to spin 1/8 turn and saw spark inside motor through small breather hole. ill rip the motor out today and see if it turns without tension. if no response from motor ill invest in the side winder 3 brushless and esc combo from CC. also i read that titan motors cant be rebuilt.
    Indiana
    733
    If your looking to go brushless now would be a good time if you got the cash, if not there are several brushed motors that can be bought cheap and a lot better reviews then the titan 12T
    Let's Go Steelers!!!... KCCO
    Jul 2013
    So Cal
    54
    I did not fry my Titan, but I did upgrade to the vxl. it's a whole new level of fun!. Traxxas has a trade up program where you can trade in your Titan to a VXL for $130.
    Aug 2013
    Corpus Christi, Texas
    379
    get the short course truck edition sidewinder!! much better than the regular sidewinder 3
    Aug 2013
    Colorado
    i burnt out 2 of them since they arent waterproof, brushless is too expensive
    19,430
    Quote Originally Posted by rc_driving View Post
    Brushed motors do fine in water but the brushes tend to wear faster.
    Alt-248 on the number pad =
    13,773
    Quote Originally Posted by dontlift19 View Post
    Isnt that the mmp, not sidewinder???
    Ya can't polish fertilizer...
    Aug 2013
    379
    No, the sidewinder 3 sct edition comes with the same esc as the sidewinder 3, just with a fan built onto it. The major difference between the sct edition and the regular one is that the sct edition comes with a 4 pole 1410 3800kv motor. The only downfall to this system is that it's not waterproof.
    Michigan
    7,683
    Imo that is the way to go if money isn't a worry.
    I dont believe the sv3 can be purchased with the 3800, just the 4600 and 5700, possibly higher kv's.
    But again I would get the mamba max if you can, nothing wrong with the sidewinder, i still run them.
    They can be an issue when we drag race running 3s however, they tend to get warm rapidly in a slash.
    illinois
    637
    what is an ok temp for the sidewinder esc - i do see the sidewinder gets hotter quicker than the vxl-3s, even with the fan on it.
    "Jedi Master"
    Lansing, Mi
    373
    Quote Originally Posted by Rc_REV View Post
    The heat syncs can approach 150 degrees witch is not dangerous but much hotter than many esc on the market. You can mount the motor fan on the esc with zip ties and drop the temp 10-20 degrees.
    My wife hates it but I love It.
