Results 1 to 11 of 11
    Mar 2014
    3
    Will Castle 780kv fit xo-1???
    I have a Castle 780 kv motor that I want to install into my xo-1. Can this be done? And if so, what modifications will have to be made for fitment? Thanks.
    Nashville, TN
    2,072
    I believe the can itself is too large to physically fit without significant modification to the chassis and motor mount. You may have to get some custom parts made for it to work.
    7,261
    Just how big the motor can? Others running 5 scale motors with 5692/5682 can but, it need some modding on the mount or buy one from high gear rc.
    Nashville, TN
    2,072
    Also, with that motor, you would have to run 12s to get it to spin as fast as the stock one. So, unless you can gear it way up and get 12s lipo, you may actually run slower than what the stock motor can do in that car.
    RC Qualifier PowerDemon's Avatar
    Jun 2011
    Fredericksburg, VA
    403
    Quote Originally Posted by Jws1982 View Post
    The 780kv CC motor can only be run on 8S right?
    37 Fightercat Shocker
    Traxxas Spartan
    Traxxas Employee TireSlinger's Avatar
    Sep 2010
    850
    I believe it's rated for 8s but it's so huge I'm sure you could compensate with gearing if you could find a pinion that big.
    Jun 2011
    Fredericksburg, VA
    403
    Quote Originally Posted by TireSlinger View Post
    That would be a big pinion gear 0_o
    Traxxas Spartan
    7,261
    Quote Originally Posted by PowerDemon View Post
    you can get one of this and run revo spur 40T
    http://www.ebay.com/itm/Spur-to-pini...item27e4edf205
    at 40T/46T gear with a ratio of 1.15:1 that should get you going fast on 8s
    Mar 2014
    3
    Thanks guys.
    Nashville, TN
    2,072
    A 40/46t combo is going to be 18% higher than the included 34/46 combo. If you run the 2028 on 8s, to match the speed of the 1717 on 6s, you'd need a gear ratio that's ~58% higher.
    Jul 2013
    204
    Highest stock gearing with stock 1650kv motor is 34 pinion, 46 spur, which translates to 121mph theoretically (i.e. unloaded) at 3,7v per cell on 6S.
    Highest possible gearing using that Ebay pinion adaptor and Traxxas Revo 3.3 parts is 42 pinion, 34 spur, this would translate to 129mph with 780kv on 8S.
    Only other source of Mod1 pinions with 8mm bore that I know is Kershaw Designs, they go up to 60t which would translate to 184mph with a 34t spur gear.
