Results 1 to 16 of 16
    Minnesota
    303
    lipo overcharge?!
    just went out to check on my lipo at its beeping overcell charge.3s at 12.73volts. hope it didn't hurt the batt. I thought my charger would stop when its done, guess not.
    Philippians 4:13
    Jul 2013
    Vancouver B.C.
    568
    Ya thats odd... My charger stops at 4.2.v ... what kind of charger is it??? Also i would discharge that extra current asap and rebalance it.. .. Over voltage will damage the cells..
    How do you charge your lipos? fast charge/balance/etc? You should always balance charge your batteries..
    Feb 2013
    PARKER COLO
    936
    Quote Originally Posted by Traxxas117 View Post
    Is the 12.73 volts a total for all 3 cells. That would be just right. I would check the battery with a cell checker and see what each cell is showing. If you have more than 4.2 volts per cell you should put the batteries on storage mode and reset them.
    "Better Old and Devious than Young and Exuberant"
    Minnesota
    303
    i don't have a cell checker. it should stop at 12.6volts. I balance it every time. I just discharged it and it worked fine. no puffing, it stayed cool.
    Philippians 4:13
    Minnesota
    303
    did the same thing again today, I was watching it slow down to .08amps then beep beep beep beep and it says error over voltage cell. wierd
    Philippians 4:13
    Jul 2013
    Vancouver B.C.
    568
    ya.. 4.20 V per cell max.. 12.60 on a 3s... Keep an eye on the charging tho...... if your charger is continually overcharging the cell(s) it can damage the battery...
    Minnesota
    303
    it was at 12.5 volts and then it went off. somethings not working right
    Philippians 4:13
    RC Champion trax de max's Avatar
    1,937
    one of the cells is exceeding the voltage limit, This is the bad cell. the other two are lower,
    Eg. c1 = 4.1V. c2 = 4.1V. c3 = 4.3V= 12.5V but cell 3 has overcharged.
    Have you noticed that the charging has been taking longer than what it used to take, and the length of time getting longer.
    Google search trumps Wiki. Refer to user guide.
    Minnesota
    303
    I got the battery two days ago and no the charging isn't longer. it is longer than other peoples on here though. should I return the battery?
    Philippians 4:13
    Feb 2007
    NYC
    756
    Just curious, what charger?
    Minnesota
    303
    hyperion eos 0403i dc.
    Philippians 4:13
    Jun 2011
    North-West Ohio
    978
    What battery?
    Edit...I seen this has been moved to traxxas lipo area.
    Whoops!
    God is good.
    Minnesota
    303
    i think I should probably return it. its a defect! its a dynamite speedpack. 3200mah 30c. I might go with spc though.
    Philippians 4:13
    waterloo .on.canada
    2,292
    defenently go with spc!
    hyperion eh
    check out what mv rateing you have per cell ....it can be adjusted below or over 4.2v per cell and battery voltage has the same adjustments........also it could be the length of wires
    summit /mustang /stampede-2s spc lipo
    Minnesota
    303
    I got the charger for free in a trade so its all I got. as long as it works im fine. I don't have a cell checker so I cant test that. the spcs are on sale now so I should get one yes!
    Philippians 4:13
    11,778
    Since they are not Traxxas lipos or charger(s) you'll need to contact the manufacturer for support of their products.
