Results 1 to 14 of 14
    237
    Easy peak plus error message
    Charging two 2s 5000mah 30c packs. One chargers to full, the other to the same voltage, but get an error. The error reads :
    Battery Vol Err
    Cell High Vol
    Bad pack?
    12,314
    What are the cell voltages?
    There are a few ways to check... with a multimeter and with a cell checker.
    If you don't have either, a cell checker can be bought for less than $5 and I feel it should be in every electric RC'rs tool box.
    237
    I'll check. Think I have a bad pack, the other charges fine.
    237
    3.71 and 3.75
    12,314
    Those are not too high... 3v/cell is lowest, 4.2v/cell is highest.
    Could be a dirty balance connector causing the issue.
    I wouldn't jump to bad pack with those normal and 100% acceptable cell voltages.
    237
    But my other pack charges fine, that's what I don't get.
    12,314
    Have you cleaned this yet?
    237
    Taken a brush and cleaned them out. Still same issue. Guess could be connector on that one pack?
    Galaxy Tab2
    USAF, Retired
    ERBE, Dewalt EMaxx, Rustler VXL
    244
    I would try switching what side the batteries are connecting to the charger on, this way you could narrow it dow to a battery or a charger issue.
    237
    No choice there, only connects to one side. The second pack charges fine, doesn't make since
    12,314
    Very well could be a balance connector/cable issue... it would take someone with pretty good soldering skills to open the pack up to fix it. I have done it before; it would almost be cheaper to get a new pack. The cost of the connector, tough tape, and shrink ended up being almost have the cost of the pack I was fixing after shipping and taxes. But I did get enough materials to do 4 packs or so... with the smallest purchasable quantities of each item.
    237
    Thank everyone for the help. I've ordered a new pack
    Galaxy Tab2
    USAF, Retired
    244
    Sorry i think I misunderstood, thought it was a dual pack charger
    12,022
    Since Traxxas does not appear to make this battery, this is closed.
