Results 1 to 12 of 12
    RC Qualifier RadReptiles831's Avatar
    Nor Cal
    841
    sway bar kit with big block?
    Just looking for a little insight on a sway bar kit and a big block. I need to tighten up my suspension and I think it should fit fine. Does anyone use them for their big block setups?
    RC Champion dcfox's Avatar
    SE Texas
    1,202
    I don't think that the rear kit will clear the motor.
    "Dude,I almost had you"
    R.I.P Paul Walker
    Nor Cal
    841
    I might get it it to try. I just put on a new 33t pinion and it raised the motor up off the shocks. What do you do to stiffen up the suspension?
    SE Texas
    1,202
    stiffer springs will help
    R.I.P Paul Walker
    Nor Cal
    841
    I'm not good with the color and spring rates. Is there a chart or something that tells the stiffest and color?
    Apr 2013
    151
    I couldn't get the rear sways to fit with a big block so I ran purple springs in the rear and the sway bars in the front and it worked out great
    Jul 2013
    Edmonton, Alberta Canada
    93
    Quote Originally Posted by RadReptiles831 View Post
    Maybe adding washers on the shock shaft to limit the amount of droop you get will help just a thought.
    Nor Cal
    841
    Quote Originally Posted by Schs2013 View Post
    Got pics of your setup?
    Jul 2013
    93
    no pictures, but i added washer to the inside on the shock shaft and one on the bottom of the shock in the link this will show you a rough idea of what i did (link is for 1/10 slash shocks but same idea applies to 1/16's) http://www.jconcepts.net/store/index...roducts_id=715
    picture is at bottom corner of link
    Nor Cal
    841
    Thanks Schc2013 i just ordered some rally shock limiters so hopefully that helps. Plus i added 2k diff fluid to the shocks.
    Jul 2013
    93
    I hope it helps you as much as its helped me. my friend said the biggest thing is that you need to work with your shocks and hisMerv can out race a stock touring car at half throttle. so that's why im sharing the info and i will eventually get pictures up for anyone else trying g to get better performance from their 1/16 i may also do it for 1/10. just got to rebuild my shocks before that can happen.
    Hope this helps
    Jul 2013
    93
    I started by adding stiffer springs 3.2 1/16 summit spring shocks set as stock i will have a picture up soon,
    Oh and adj toe links and pushrods on the way this will take alot of steering slop out.
    Just got (4)TRX7067 rally damper set this should remove droop pictures when all parts are in.
    Going to get diff oil for F/R 50K and center 120K lots of power to the wheels.
