    Apr 2013
    mississippi
    95
    forward only tranny conversion
    So I got a tranny with both forward and reverse. Got the optidrive and shift servo, etc.... well I didnt realize I only had the 2 channel 2.4 ghz remote. So the problem now is that if I jump and I land on the rear of the truck. The shift rod that goes into the tranny jars into reverse. So I wanna convert to forward only. How hard is this to do. And which gears do I remove. Ive never been inside a revo tranny. I havr tore down a few others like the jato and s maxx tho. But neither had reverse.
    Zip ties work wonders for broken shock towers!
    11,886
    Pretty much the ones that have to do with reverse. You'll buy the FOC kit and read the instructions which primarily replaces all of the output shaft gears.
    7,261
    with the FOC you'll have less rotational mass by taking all out the reverse gear, shift fork and other components along with it.
    humay has left the building, peace.
    RC Turnbuckle Jr. KyLeader7's Avatar
    Jul 2007
    5,062
    Forward Only Conversion (FOC) is a pretty simple install, especially if you've taken apart other transmissions before. The TRX directions are spot on, and VERY helpful. I would buy the kit, and do the install... Then never look back like most of us have done.
    Learn by doing
    Oct 2005
    South Florida
    19,234
    One of the Easiest and best upgrades you can do is FOC... IMHO... Pretty much the reason why reverse is now an option instead of standard in the newer models IMHO...
    All Lives Matter
