    Jun 2013
    265
    Drill new pin holes in Summit Shafts
    Has anyone broken the plastic ends of the drive shaft and drilled new holes in the ends of the shafts (90 degrees around) so you can re-use the shafts??
    I am away and have broken 2 shafts at the plastic pin holes and would love to know what size drill bit is need to drill new holes for the pins?? The pins look like maybe 1-2mm??
    Bash it like someone else has to fix it!
    May 2013
    352
    No, I just bought new ones, but you could try it maybe a good band-aid fix.
    Sep 2009
    Victoria B.C Canada
    5,430
    Have done it many times,works pretty well really
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Jun 2013
    265
    Thanks - I will buy new ones as soon as I get home, and I know it works well, just need to know the size of the drill bit that will fit the pin snuggly as I am away at the moment.
    Cheers
    May 2013
    Tennessee
    105
    Quote Originally Posted by ErbeSumm View Post
    Cheers
    If I remember correctly its a 3mm or a number 31 will work.
    Sep 2009
    Victoria B.C Canada
    5,430
    Make sure the tiny grub screw in the cv joint is tight(it holds the pin in place)
    I bought extras and added a second one on every joint.if that pin is allowed to start walking back and forth eventually
    It goes far enough to put all the pressure on the other side and snaps the plastic out.Thats my theory anyways
    they have tried
    Jan 2010
    Central Florida
    650
    1/8 inch drill bit- I created a vid on this
    http://youtu.be/pjiC9R_GLIk
    The original CRASHER: equal parts CRAwler and baSHER!
    Just do it...they make replacement parts.VXL power
    Jun 2013
    265
    Thanks mate - I pretty much did what you did and have been re-using my drilled shafts until I get back home & can pick up some new shafts.
