    5,125
    Worn Out Diff Outputs???
    Hey guys, I'm tearing my Summit down to a bare chassis so I can finally dye it black. While I had everything apart I thought I'd clean the diffs and what not. But, I found one of my Avid bearings had seized up on the outer diff lock side of the diff. The bearing is fine now, I have no idea why it stuck. But because the bearing seized, it acted like a bushing with the diff output rubbing inside the bearing. If I put the bearing back on the output shaft, it still acts like a bushing, because the output shaft got worn. The bearing is smooth, but it just won't spin... Any ideas on how to fix with out buying a new shaft for $10? I thought about lightly painting them to make the shaft "bigger" but I don't know if that will work. Thanks!
    Anyone?
    Please don't bump. We'll get to you, probably sooner rather than later.
    -ksb51rl
    2SummitE/TmaxxVillainSlash2&4SlayerPndeTetonXMaxx
    South West PA
    40
    I dont own a Summit yet, but, I would replace both the shaft and the bearing. If painting it would work, it would be hard to tell for how long, as it would be a temporary fix at best. I would replace the bearing as to not knowing the cause of it seizing up, and having to worry if it is going to do it again, and having the same problem.
    Jun 2013
    265
    Spend $10!!!!
    1,302
    Spend some money and get new bearings. You can pick up some ceramics sets for under $20 on eBay.
    Canmore, AB
    330
    Try wrapping it in aluminum foil.
    Working hard to appear reasonably sane.
