Results 1 to 8 of 8
    May 2013
    North Western Indiana
    232
    STRC front shock tower question.
    I got the STRC front shock tower and bulk head, and the shock tower is puzzling me. the tow linkage is weird, if the tow linkage is set on the middle hole the left is pointed way in. If it is the out side hole it is the same but the tires are at a weird angle vis versa for the inside hole. I don't know if this is normal or if the part is a defect. You in put would be nice.
    Jun 2013
    368
    Anyway to get us some pictures?
    May 2013
    232
    not right now this is kind of the problem im having
    http://www.google.com/search?q=STRC+....%3B1040%3B780
    Apr 2009
    Michigan
    2,297
    Adjust your links.
    Oderint Dum Metuant
    May 2013
    232
    I did i have on that is right middle hole, and the left is farthest hole
    Apr 2009
    Michigan
    2,297
    Adjust the length of your links. If your using the non adjustable ones buy some that can be adjusted. Just moving the mount wont do much for you unless your adjusting to suspension height.
    Oderint Dum Metuant
    Dallas
    578
    Yeah, sounds like you just need to adjust your camber links (the top link). The toe can't be changed by changing the shock tower, fortunately, but if you have a XL5 model, now would be a good time to upgrade the whole truck to a set of VXL links. They are very strong 4mm steel turnbuckles with captured rod ends that are both stronger than the stock "popsicle sticks" and will allow you to adjust front and rear camber, and make toe adjustment easier.
    May 2013
    232
    So get VXL turn buckles 4mm?
