Results 1 to 26 of 26
    May 2013
    352
    Just installed MM2 in my Pede
    Well ladies and gentlemen, it seems as if I have solved my pede problems ( knock on wood ). I installed a MM2 with a 2650k motor today. Had to move things around. ( I can show pics if interested ). But it's installed and it's vicious. Before I ran it, I put a cage on. Man ol man, that cage is a must if you are running any Castle Creations ESC/motors. My Pede will flip at full punch at 45 mph. It's sick fast and extremely powerful.
    Enough of that for now. I DO have a question.. On the esc there is a red/black wire... what is that for? also, my fan does not turn on, is that because the esc is not hot?
    here is a pic.
    Jun 2013
    11
    woah sounds like a torque monster. Do you have a wheelie bar to reduce the back-flipping?
    The fan wire needs to be plugged into the receiver. The black wire should be plugged in alignment to the brown wire of your MM2, which usually is the outer pins on the receiver
    South of St Louis
    6,152
    I'll bet its a beast.
    The fan on my newer MMP only turns on when it gets warm. And the fan needs to be plugged into the esc.
    May 2013
    352
    Quote Originally Posted by PK Blade View Post
    Yeah, I have wheelie bar..., it does no good
    it needs to be plugged into the ESC? You mean the receiver? I'm lost, I don't see a place for it to plug back into the esc, its comming from the esc.
    USA
    230
    yes reciever any port except 1 and 2
    May 2013
    352
    Ah, okay, thanks
    USA
    230
    Quote Originally Posted by rcapilli View Post
    Thats why I am not getting one, just a rear bumper to deflect from the body being ripped off when I do backflips.
    May 2013
    352
    I have a cage on it. So that takes the beating.
    USA
    230
    I have a cage too, broke it in 3 spots so far, just not strong enough.
    May 2013
    352
    YIKES Man, that's some serious bashing !!!!
    Quote Originally Posted by makuloco2000 View Post
    Wales in the UK
    6,462
    Maybe you guys should make one that can take a beating.......peace
    The Netherlands
    39
    Make your own body out of 3mm lexan?
    USA
    230
    Yeah my friend just bought a new welder. We are going to try some flat stock as cross braces. Just dont want to make it too heavy.
    Wales in the UK
    6,462
    Dude that's a sick idea man maybe do some research on real rollcages and get tips on making it strong but light ........peace
    Apr 2013
    Moscow Idaho
    66
    rcapilli, Can you post pics of the install? I have the MM2 and 2200 on order at this time so I will be tackling this at some point. If you have any tips or pointers that would be great. Like they say go big or go home! LOL
    McKinney, Texas
    811
    Quote Originally Posted by Joe596 View Post
    Here is a video installation I got from someone on youtube.com for you. All you do is dremel down the chassis just a little bit to fit the 2200kv motor. You can fit the MM2 where the stock ESC used to be or simply put it in front then move the receiver box where the stock ESC was before.
    http://www.youtube.com/watch?v=MYt1AKQVf2E
    The only difference is that the 2200 is longer then the 2650 motor. Here are my pictures of my MM2 & 2200kv motor. As you can see my dremel skills are horrible but it did the job so I just went with it.
    Apr 2013
    Moscow Idaho
    66
    Look good. In some of the pics the esc is up on the side will that work also or would it be best to put it where the receiver box was and move the receiver box in front of the motor? Thanks for the pics and the help.
    McKinney, Texas
    811
    It's really up to you if you want the ESC in the front or the side. I'll probably move my ESC in the front but I'm too lazy to do some small fabrications since I upgrade to this combo I have only had 3 fun bashing times.
    May 2013
    352
    I did what the pictures showed above. I placed the ESC at the top of the Pede. Just got some plexiglass and made a shelf for it. Used double sided 3m tape to stick the esc to it. Had to dremmel some plastic, as shown above, but everything went together great.
    Apr 2013
    Moscow Idaho
    66
    Thanks for the tips guys. It will really help. The combo should be here in 2 days. I cant wait. I have read your guys post on this and it seems like it is the way to go. Your pedes are sweet I just hope my turns out half as good as your guys. Thanks again.
    Wales in the UK
    6,462
    Just get ready to tame the monster power you will have dude......peace
    Apr 2013
    Moscow Idaho
    66
    I cant wait. It should be sick. I just hope it turns out good. LOL P.S spenniepoos your pede is sick.
    Also what gearing should I start with? Stock or 18/54 or something else. I like doing speed runs and also going to the skate park, running on grass, dirt and anything else I can find.
    May 2013
    352
    hahahahahaha. Joe596........ It's gonna be a monster. at 45mph, I can still do a wheelie and flip my pede. It needed a roll cage to protect it from myself Just take your time with the install. Do it right and don't rush it. You will see a HUGE difference in speed and torque.
    Wales in the UK
    6,462
    Mine does the same with the tenshock 4 pole but I bet your motor is not even warm after where mine is in the 148f-159f area.....peace
    Apr 2013
    Moscow Idaho
    66
    What batterys are you guys using in your pedes? I have a 2s and a 3s right now and if I remember right I can go to a 6s? But I was thinking about a 4s. What do you think? Thanks.
    Wales in the UK
    6,462
    I think 4s is more than enough power dude just look for a high mah and c rating for a long runtime bro....peace
