Results 1 to 12 of 12
    Apr 2013
    Ontario, Canada
    778
    NA`s Newly Aquired...
    Hi All,
    Just picked up my first 1/16. Its only 6 months old, I got it from a friend for $200, Just needs a little TLC. Pretty good deal I figure. Almost enough spares for me to make another truck
    Here is what is on the truck right now:
    -Aluminum Hexs
    -Aluminum Pillow Ball Caps
    -Steel Hollow Balls
    -GTR Aluminum Shocks
    -RPM Revo A-Arms
    -Revo Axels
    -Revo P2 Rockers
    -Locking Green Wheel Nuts
    -Green Towlinks/Pushrods
    All just need to replace the steering servo, broken front/rear post mounts and cracked front bulkhead. Plastics are already in the box. Ordering the servo soon.
    It came with 5 sets of tire:
    -Canyons with Chains
    -Trenchers
    -Road Rages
    -Dirt Hawgs
    -Talons
    Here a list of the spare parts box:
    -Transmittion
    -Screw Set
    -RPM A-Arm Set
    -Front/Rear Diff Housing
    -Slipper Clutch Kit
    -Body Pins
    -Center CVD`s
    -50t Spur Gear
    -26t, 19t, 16t pinions
    -x6 Axle Carriers with Pillow Balls and Bearings
    -x4 Revo Drive Shafts
    -x2 2080 Gear Sets
    -x2 Complete Diffs
    -x2 Purple Spring
    -x2 Blue Springs
    -x4 LT Rockers
    -x4 Summit Hex
    -x4 Slash Hex
    -x4 Wheel Nuts
    -x3 Dead 2080s for parts
    -Stock Summit Shocks, A-Arms, Axels, Pushrod, Towlinks All Round
    -Stock VXL ESC/Motor
    -x4 1200 NIMH Batts
    -Grave Digger Plastic Kit
    - Wall Charger
    -Axial 14-LED kit
    So my plan is to rebuild the Summit into a Summit, and then use the remaining parts to build a Merv.
    So I`ll have two like new 1/16`s for like $250
    I will be starting threads covering both builds. I dont know much about these 1/16`s. But I do also have a full size Summit so I am familiar with the rig.
    Ventura, Ca.
    256
    You scored! I'm kinda jelouse...
    Mini Revo VXL 7107
    E-Maxx 3903 - He Lives!
    Alma, Michigan
    12,315
    That is a good deal!
    What servo you going with?
    muscoda, wi
    1,245
    WOW.... That is quite a collection of new parts that came with the mini. GREAT DEAL
    Apr 2013
    Ontario, Canada
    778
    Quote Originally Posted by Little Smokey View Post
    thanks, I know it was a deal. friend/mechanic discount
    either the hitec. probably blue or green though.
    what do u suggest? also alum steering components?
    Quote Originally Posted by ajcar View Post
    yes, we both knew he had a lot. we made the deal even before we opened the part box. as we went through tires n spares we realized I got a killer deal.
    Edited for bypassing the language filter. DO NOT insert symbols or letters in an attempt to get around the language filter; doing so is against the forum rules.
    Alma, Michigan
    12,315
    There was someone that tested out multiple aluminum steering components quite a while ago... they tried 3 or 4 different brands and they all had the same result; they all burned up the aftermarket servo. After it was all said and done he suggested to just use the stock servo saver and possibly an aluminum Y post if you must.
    Apr 2013
    Ontario, Canada
    778
    Hmmm... Maybe just stick with the stock setup I guess.
    What is the BEST servo you can buy for these 1/16`s?
    Alma, Michigan
    12,315
    Don't know for sure... all I used was a 390 and since I was happy I stopped looking. lol
    Rotterdam, Netherlands
    7,864
    $200. Man, that is almost for free. Well done.
    Jul 2012
    Yakima, Washington
    1,440
    I wonder how well those big trenchers work?
    Apr 2013
    Ontario, Canada
    778
    Quote Originally Posted by revoman78 View Post
    verywell. however. different hexs are required. first I was using slash hexs cause they are a lil thicker. then upgraded to aluminum hexs.
    definetly need a stronger servo with them. going to try a 390 I think.
    Apr 2013
    Ontario, Canada
    778
    I ended up buying a new brushed merv and used all the goodies I got in the 1/16 lot to build a VXL Merv and brushed Summit.
    Check out NA`s Mini Summit Build -----> HERE<-----
    Check out NA`s Merv Build -----> HERE<-----
