    Jul 2013
    Estevan. Saskatchewan
    9
    need help with spur gear.
    Hi there. Just found out that I missed 1 friction pad from slipping clutch and now the spur gear is not going straight. I am not sure if I can drive it like this or I should buy a new one. Here are some pictures so you can see better, please help.
    Gurley, Alabama
    796
    No, don't drive it like that. You need to replace the missing slipper pads and that should straighten everything back up.
    Jul 2013
    9
    Thanks. I didn't drive it since I found that I am missing this pad. I hope it's not hard to put a new one because I didn't find anything about it in manual.
    183
    all you have to do if you have ballpoint metric hex wrench sets you take the motor and the tank off unbolt the spur install the pad and then reassemble in opposite order.(if you have Loctite use it to keep the screws in place because I keep losing screws every where).
