Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    Jun 2011
    North-West Ohio
    978
    Easiest way to find out with the switch is to plug a battery in and flip it. When you plug it i
    In and you hear the fan running and beeping right away, that's the ON side. If nothing happens, that's the OFF side.
    God is good.
  2. #42
    Lafayette,LA.
    711
    I believe on is towards the black wire. Once you figure it out just make a mark so you will remember. Good luck.
    Sent from Oser world
  3. #43
    Jul 2009
    indonesia
    63
    Just finish setup today.
    The on/off switch is toward the black wire.
    Calibration & programing run successful.
    set the lipo cutoff to "none", and its works good my traxxas 7cell nimh.
    A little bit noisy at the gear. I use stock 48p, because the 32p didn't fit. (motor shaft is to short). I think I have to buy HR spur to fit the pinion.
    I run 23/86. I have to gentle on throttle to start running. Have plenty of torque & good top speed.
    It's a good starting. I like this combo. Easy setup & good quality product.
    Will updating photos & video soon.
  4. #44
    Jul 2009
    indonesia
    63
    updating my slash.
    i have a lot of fun time bashing with my slash.
    i still use 7cell Nimh. it's fast, but can't do wheely. i think it's because the battery. i will upgrade to lipo soon and see the different.
    i use 14t pinion & 54t spur 32p.
    the temp. with this ratio is 110 degree F. i think i can gear up to get more top speed.
    i use my heli gyro. it helps to keep the nose straight forward.
    gps for measuring speed.
    i only got 50km/h with this setting.
    next, i'll find the gear setting to get more top speed with nimh first, before using lipo.
    i plan of using 17/54 or maybe 19/54.
  5. #45
    Michigan
    6,800
    One thing you can do if speed is your thing,is take some of the rear toe out.
    It might be a bit snakier at lunch,but will increase your top end.
    There going to have drag races here next week.
    I'm going to watch,but my trucks will stay sct's.
    Just not a speed freak.
    Your doing well for a NiMh battery.
  6. #46
    Jul 2009
    indonesia
    63
    thanks billy.
    i'll try your tips to toe out rear wheel soon.
  7. #47
    Jul 2009
    indonesia
    63
    @billy-bones,
    how can we set toe out for slash rear wheels? i think it's fix. we only can adjust chamber on slash.
