    Apr 2013
    9
    Question TQ 6516/6517 Servo Reversing?
    Hello,
    Does anyone know how to reverse the servo direction on this radio? There is only a "Setup" button on the top. I went through the paper work that came with the Merv and cant find any instructions for doing this. Search on Traxxas support didnt help either. Thanks
    Frank
    Minneapolis,MN
    31
    Steering reversing procedure:
    1. Press and hold the SET button on the transmitter for two seconds.
    The status LED will flash green.
    2. Turn and hold the steering wheel to the full left or full right
    position (it does not matter which position you choose).
    3. While holding the steering wheel in position, press the SET button
    to reverse the channel.
    4. The channel is now reversed. Confirm correct servo operation
    before running your model.
    Throttle reversing procedure:
    Note: Throttle reversing is often times unnecessary on electric models,
    as issues with the throttle can usually be solved by reprogramming
    the speed control and/or verifying that the motor is wired correctly.
    Before attempting to reverse the throttle channel using the procedure
    below, you should first recalibrate the speed control. Refer to “Setup
    Programming” on page 16.
    2. Move and hold the throttle trigger to the full forward or full brake
    3. While holding the throttle trigger in position, press the SET button
    4. The channel is now reversed. Recalibrate the speed control and
    then confirm correct servo operation before running your model
    Apr 2013
    9
    Thank You!
    Frank
    1,334
    DL the online manual. It is in their.. about half way through
