Results 1 to 22 of 22
    May 2013
    Elk City, ok
    48
    Revo 3.3 hard to start and dies
    As the title says I can get my revo to start and run but if I gas then brake it dies and won't start back up. I Have reset needles and tried adjusting everything glow plug is good any help would be greatly appreciated
    Mar 2013
    Australia, vic
    137
    Make sure your idle gap is set properly..
    .7 - 1.0mm
    May 2013
    Elk City, ok
    48
    I have checked everything and its all right on the money the first time I start it it fires right up but after it runs for a bit it dies After it dies it takes me most of my ez-start battery to get it going again
    Jul 2006
    2,286
    How long is a bit? Is that the time that it takes to warm up the engine? Are you saying that the engine dies after it warms up, dies, then you can't get it started?
    Believe 1/2 of what you see,and 0 of what you hear
    May 2013
    Elk City, ok
    48
    Yes the short amount of time it takes to heat up then dies and hard to restart
    Riverton Utah
    5,271
    Sounds like the engine is worn out... How much compression does the engine have?
    My life is busy, but I'm still lurking! 24 RC's
    Jul 2006
    2,286
    +1 .
    May 2013
    Elk City, ok
    48
    How do I tell I'm new to the nitro rc business
    Riverton Utah
    5,271
    Under your Revo spin the flywheel by hand, and if it gets harder to turn over at one point, then gets easier, that's the compression.
    May 2013
    Elk City, ok
    48
    When I spin the fly wheel at tdc it gets tight and then looses up once I pass it
    Riverton Utah
    5,271
    Ok, then is has some compression... When you take the glow plug out, what color is the top of the piston?
    May 2013
    Elk City, ok
    48
    It is like a brass or golden color depends on the lighting
    Riverton Utah
    5,271
    Ok, than that's good thing! A light brown/golden color mean the engine has been ran with a good tune. If the piston is black, or dark brown on top that means it had been used too lean.
    May 2013
    Elk City, ok
    48
    With it dying at running temp think its in my tune or possibly a seal on my gas tank
    Sweden
    40
    Some compression when it's not at work temp (guessing you didn't spin the flywheel directly after a run). Maybe it's not enough compression when it reaches work temp and that's why it dies?
    Are any screws that holds the cooling head loose?
    http://youtube.com/adolfss0n
    Riverton Utah
    5,271
    Try checking for air leaks by spraying soapy water one the fuel lines and gas tank, and see if anything bubbles.
    8
    Sounds like the sleeve is losing pinch when it gets up to operating temp.
    freeks come out at nite...
    Mar 2009
    1,968
    sounds like its worn out..
    and for the record black on top of the piston means to rich not to lean.. to lean will give a pitting effect to rich will give you carbon build up.. also black on piston head is directly related to what type of fuel used.. just an FYI
    you know.. i never had a sig.. but i do now...
    May 2013
    Elk City, ok
    48
    So what's the solution for a worn out engine replace the whole thing or can it be rebuilt
    Mar 2009
    1,968
    buy a new one for about 100 bucks on ebay
    Riverton Utah
    5,271
    As stated, you could buy a new one for $100. You could also buy a new piston/sleeve for it for about $65 if the bearings and crank are in good shape. http://www.dollarhobbyz.com/servlet/...TRX-3.3/Detail Hope this helps!
    May 2013
    16
    Also TRAXXAS has motor replacement for $110.00 with warranty on a brand new motor.
    Just to let you know
