Page 2 of 6 FirstFirst 1234 ... LastLast
Results 41 to 80 of 225
  1. #41
    Jul 2013
    Saskatoon, SK. Canada
    2,187
    Bummer Clint The upside is new parts! Woo-Hoo!!
    Kate and Jordan come home from Edmonton with my Slash Ultimate Seeing as I have no working surface toys, I went to the flying field, it was a good day.
  2. #42
    Saskatoon Saskatchewan Canada
    347
    That's what I like to hear!
    I'm happy with the new parts; I hope to pick up a new motor soon.
  3. #43
    Temecula,CA
    2,119
    Gosh you are such a bad luck charm, so many things went wrong. But at least the events are helping you upgrade
    Slash 4x4 LCG, Rusty VXL(not runnin), and my bike.
  4. #44
    347
    All is well with it again.
    Installed the ESC.
    Not a fan of the extra wiring and I still need to make a mount for the on/off switch.
  5. #45
    Jul 2013
    2,187
    Okay! Ready to Roll!!
  6. #46
    55
    Nice build Clint!!! What motor mount is that??
  7. #47
    347
    Thanks.
    It's the Golden Horizon big bearing motor mount.
    I like it so far.
    A buddy of mine and I took our cars out to the local BMX track this evening. I bashed the crap out of it; the only problem is the Velcro I used to hold the ESC down is not sufficient; and the TQi receiver is still giving me problems; if I lost sight of it over a jump I would loose signal; so I guess I'll need one of those.
    How's this for bashing?
    I'm going to make a proper mounting plate for the ESC now; and buy some 3M double sided tape.
  8. #48
    Jul 2013
    2,187
    Nice work, way to do your part Clint! That video jump, back flip was huge!
  9. #49
    347
    Finally after a long wait my Proline Badlands showed up. I can't wait to tear up some dirt with these!!
    As for the Bandito road tires that were on the wheels before; I will be getting a different set of wheels for them and glue them this time.
    Not sure what to go with for wheels yet.
  10. #50
    Jul 2013
    2,187
    Looks Great Clint!
    I went to HW during lunch, and they didn't get any PL beadlocks in So I ordered a set on ebay with Badlands.
    I would like to get a set of rims that are bigger in diameter so I can have lower profile tires for that cool look
  11. #51
    347
    That's awesome! Great minds think alike.
    I'm not too sure what tire and wheel would give a lower profile side wall unless a person went to a 2.2" or 2.8"
    I have had the 2.8" test fitted on it, but decided against it until I get a better servo, body lift, and figure out the shock rubbing clearance issue.
  12. #52
    Jul 2013
    2,187
    Yeah, the whole chassis and body clearance is going to be hit or miss. I was thinking a set of Stampede wheels, but then they may not clear the body and require cutting the fenders of the truck body. You maybe able to get away with it on the bug body.
    You would think this is something easily made by Pro Line. Just make the front diameter of the rim the same as the back
  13. #53
    El Sobrante, Ca
    8,825
    Hello, I have been reading through your build. I think I can offer a little help to you. You got the Banditos! They are an excellent tire! You are having trouble with the truck rolling over? I had the same problem and the way I was able to solve that problem was to put thicker fluid in the shocks. My street Slash sits as low as possible but my ( Ultimate ) basher was a different story. So I went off the deep end and put 80 wt oil in the shocks! It worked! It doesn't hardly roll over at all. As to what rims to put the Banditos on, you could order more beadlock inserts for them. That way all you would have to do it slide them on the beadlock wheels when you want to run in the street. The Badlands are an amazing off-road tire! Just make sure to rotate them. I switch the other side of the truck they are on so they wear evenly! You have a great looking truck! Keep up the good work!
  14. #54
    347
    Thanks very much! I'll pick some up this week.
    80wt installed.
    I'll test it out tomorrow.
  15. #55
    Jul 2013
    2,187
    Nice, you have me wanting to change mine out too! I got the Aluminum shock caps for Jordan, lets hop it stops his blowouts!
  16. #56
    347
    It's been a while since I've had a chance to play with my Slash, the hobby store had a bunch of goodies there today that I figured I must have.
    Picked up another Bug body and a 1979 Ford F-250 body, some aluminum steering bits, front MIP drive shafts (rears will be in next week), couple of new bearings for the big bearing motor mount, paint, 15 tooth pinion gear and finally a Castle 1415 motor to go with my Sidewinder ESC.
    Pretty excited.
  17. #57
    Jul 2013
    2,187
    Whooaa...! Look out baby!!!
    Nice Acquisition Clint!
    Did the HS get more paint, ore are you just picking through what they have? I was needing white and it looks like you got some!
  18. #58
    347
    Thanks!
    It's just the white for the inside of the body, they didn't have much; I wanted white and black as well.
  19. #59
    Jul 2013
    2,187
    Ahh...
    We should get together soon for some speed runs! Or general bashing!
  20. #60
    Temecula,CA
    2,119
    Looks good! Did you change the bullets on the motor/esc?
  21. #61
    347
    I completely agree! Next week for sure; if not sooner.
    Quote Originally Posted by sean1214 View Post
    If I recall correctly.... Maybe.
    I have two sets of them if I need to.
  22. #62
    Jul 2013
    2,187
    Okay, should be fun!
  23. #63
    May 2013
    Uk
    742
    Ooooooo.......goodies.....yum.....nice....great stuff you got there clint
  24. #64
    347
    Looking forward to getting it all installed; I have had an idea rolling around in my head for a paint scheme on another Bug body; it won't be any ViperZ paint job lol! I promise it will something different...
    The old Ford is going to be Saskatchewan Roughrider green I'm thinking.
  25. #65
    Temecula,CA
    2,119
    Nothing wrong with a basic paint job, just keep it posted on how it goes.
  26. #66
    Jul 2013
    2,187
    Should look nice Clint!
    I went to the store today after work and there was no new paint, so I bought the 2 remaining cans of Florescent backer white, to use as white. It should do the job fine...
  27. #67
    Aug 2013
    11
    Roughriders green I think it should be blue and gold after last weekend lol
  28. #68
    347
    Easy now!!!
    Lol!
    Quote Originally Posted by ViperZ View Post
    Sounds good!
    Oh it won't be basic; I'd call it abstract...
  29. #69
    Jul 2013
    2,187
    Now if only I could get black... Not even in stock in the Parma bottles to airbrush
  30. #70
    347
    Picked up the rear MIP CVD's and put them together this morning.
    Also grabbed an 18 tooth pinion, new lights for the front bumper, and some paint.
    Now I just have to make time to put the rest of it together.
  31. #71
    Jul 2013
    2,187
    Looks Good Clint! You will get a kick out of the new power plant!
  32. #72
    Omaha, nebraska
    219
    You should get some stainless steel screws for your truck so they won't rust out and strip!!nice on the upgrades looks really good!
    Yes I do have a Traxxas...
  33. #73
    Jul 2013
    2,187
    Quote Originally Posted by Stampered4x4 View Post
    I second that! I have a box of Stainless screws coming just because I find I'm needing replacements
  34. #74
    347
    I'll be doing that eventually.
    Well I put the motor, ESC and other goodies I bought on, I wasn't able to put on the MIP axles on the front because they were missing one of the "barrels" that couple the CV joint; I called MIP and a new one is on its way here (very happy with that). I ran it slowly after I put the rear axles on and found a bit of lateral play in the output shafts, I replaced the diff cup and all the bearings in the rear bulkhead and there is still a touch of movement.
    Then I took it out to test and play... Wow! I never thought I would see it wheelie! I had the 18t pinion and 54t spur in it; the motor temps were no more than 107 but the ESC went to 140.
    I'm going to put the 14t I have in it and test that out later.
    Needless to say; I'm very happy with it.
  35. #75
    Jul 2012
    Mesa az
    398
    Quote Originally Posted by Clint Cart View Post
    If you had good temps and you liked it then why would you want to go lower if they were that low then you can go even higher.
  36. #76
    347
    Because speed kills. Hahahaha!
    I should also mention that the ESC went into thermal protection at one point; so it needs to be rested more often or slow it down. I'm going to get a fan for the ESC if my Traxxas fan doesn't fit it.
    Okay guys and gals; I painted a new body today; how's this for different?
    I call it polka dot graffiti.
  37. #77
    Jul 2013
    2,187
    Psychedelic Clint! I like it!! Good to hear you are getting wheelies Mine is geared at a 20/54, and will wheelie if the traction is really good!
  38. #78
    May 2013
    Uk
    742
    Hot dog clint......that is psychedelic ....yeah baby yeah...very good indeed.....
  39. #79
    Jul 2013
    2,187
    ^^^ Makes me want to paint a Groovy Bug too!
  40. #80
    347
    Thanks gentlemen.
    I picked up a JConcepts cover today for all the important bits inside.
    I would prefer an Outerwears cover but for now I'll try this. I'm going to watch my temps for the first few runs, I cut out all the duct holes for air flow as well.
