Results 1 to 7 of 7
    Calgary, Alberta
    47
    Help with TTQ 2.4GHz and Receiver
    Hey Folks...
    Was out tonight and the daughters Pede was acting up.
    Very short range <100 feet.
    I changed the batteries in the remote but no luck.
    Any thoughts?
    Thanks for any help you may offer.
    12,311
    Check for a damaged antenna wire.
    Calgary, Alberta
    47
    Yep, you guessed it. Somehow got crimped up underneath the battery.
    Can I just tape it up and continue on or do I need to replace the antenna wire?
    12,311
    Taping it up probably won't cure the issue... but it is worth a try because you won't be out much.
    If you decide to replace the wire... it is a micro coaxial that is soldered directly to the circuit board and 3.25cm (I believe) of its core needs to be exposed at the tip. To solder this coaxial takes some pretty good soldering skills.
    One more way to possibly fix it yourself is to expose the length mentioned above of the core after the break... when going from the tip down to the receiver. It may work... it may not.
    One way to fix it for sure is to use Traxxas' lifetime warranty program:
    http://traxxas.com/support/Traxxas-L...onics-Warranty
    or to buy a new one (or set) off from eBay.
    Another thing to keep in mind:
    http://traxxas.com/support/Traxxas-T...tibility-Guide
    Calgary, Alberta
    47
    Thanks Jimmie. The antenna itself is not actually broken just the black protective coating has been rubbed off. I will try to tape it up and if not, I will follow your other advice.
    82
    before you tape it I would try heat shrink. it wont unravel like tape and would be permanent. you can get it at radio shack or any electronics store.
    Calgary, Alberta
    47
    Just to let everybody know. I finally got around to heat shrinking the antenna and tried it out. No luck.
    Just going to buy a new 2218X.
