Results 1 to 12 of 12
    Jul 2012
    Saint Louis, MO
    504
    Charger for my traxxas lipos
    I have a few traxxas 2s 5800 mah packs and an onyx 245 dual charger. For some reason the onyx does not fully balance the packs. I get one at 4.20 and the other cell at 4.18. That is an example but you get the point.
    I want to upgrade chargers and am looking at an iCharger but not sure what all I need to charge two packs at the same time. Also does it balance both packs?
    I know I need a power supply but that's about all I know.
    Sent from my iPad using Tapatalk HD
    Alma, Michigan
    12,314
    iCharger makes a great charger, that is for sure. I have hundreds (possibly even 1,000+) charges on my 206B... most of those were with a ParaBoard, charging up to 6 packs at once... all in perfect balance.
    From the mAh count of your post I am going to suggest the 206B or larger... charging two 2S 5800mAh packs in parallel at 1C would be 11.6 amps and the 206 is capable of up to 20 amps.
    Yes, you will need a power supply.
    Jul 2012
    Saint Louis, MO
    504
    So what if I want to charge 4 packs? I'd need the one that does 30 amp?
    19,551
    You don't NEED to charge all 4 packs at 1C. Charging them at the maximum 20 Amps yields full charge in a out 75 minutes. That's a lot faster to charge 4 than 1 hour each.
    A word of caution: if you are going to parallel charge, PLEASE make sure you know what you're doing and know the conditions necessary and the risks involved.
    Alt-248 on the number pad =
    Alma, Michigan
    12,314
    If you want to charge at 1C, yes. Charging at less than 1C does not hurt anything. 23.2 amps would be 1C for 4 packs, 20 amps would be .86C.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    All the power you will ever need at a resonable price...
    http://traxxas.com/forums/showthread...w-Power-Supply
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Marshal carraig042's Avatar
    East Tennessee
    6,752
    No kidding, that power supply is a beast and a really good price too!
    -Brett
    4wd Sportmaxx 3.3
    Jul 2012
    Saint Louis, MO
    504
    So what am I missing?
    1. I am getting an icharger 206b or 306b with power supply from progressive rc I think
    2. I am ordering the parallel balance board for traxxas
    3. I know to charge same cell packs. All I have are 2s packs and I will probably only charge two identical packs in parrellel instead of 4 or 6 as the mah are different.
    The one question I do have is does the para board work for storage mode or to just charge one pack?
    I've been reading up on this and think its time to jump to the next level charger.
    Alma, Michigan
    12,314
    Paraboard works in any mode.
    The packs do not need to be the same mAh to parallel charge them. The only requirements are that they are the same cell count and very close to the same voltage.
    Here is some reading for parallel charging:
    https://sites.google.com/site/tjingu...allel-charging
    Jul 2012
    Saint Louis, MO
    504
    Thanks. Will give it a read.
    Jul 2012
    Saint Louis, MO
    504
    My new charging kit will be here tomorrow. I ordered the surface 500 watt combo from progressive rc along with a paraboard.
    Can't wait.
    904
    To go back to the orig post, I don't think a 0.01v matters very much or at all. Sometime my charger beeps when one is 4.20 and the other is 4.19. Sometimes 4.19 and 4.18. Definitly not worth 100$ for a new charge imor
