Results 1 to 19 of 19
    Apr 2013
    Slash 4x4 MIP axles on a Stampede 4x4?
    Has anyone ever done this before? My LHS has axles for a slash, but not for my stampede. Is there any interchangeability here? I'd really like to have my truck for the weekend and would rather not wait for shipping.
    Lafayette,LA.
    712
    As far as I know as long as they are slash 4x4 you are good to go. Should be the exact same thing. Make sure you get slash fronts and rears. Good luck.
    Sent from Oser world
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    They are the same really the only difference in the two trucks are the chassis and obviously the tires, bumper and body.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Wales in the UK
    6,462
    Just remember to use a little red threadlock and good tools and then let sit for 24 hours to dry and your good to go bro....peace
    Rotterdam, Netherlands
    8,238
    There is no difference in the stock axles and neither in the MIP ones. It's just that Traxxas uses the same part numbers and MIP made new part numbers for some reason. Strange enough they didn't change any part number from separate parts.
    Mar 2013
    27
    I had asked a question in 2 other posts but never got a reply but since theres a blue print to refer to I'll ask again. Part # 10127 is a rear bearing crush spacer is this to be installed even though I have aluminum casters, bearing carriers & steering knuckles?
    Northeastern CT
    235
    are you talking about the 17mm hex's?
    Stampede 4x4 vxl w/ MMP/2400kv, Mini E-Revo
    Oct 2012
    Easton, MD
    680
    Quote Originally Posted by gjgriff View Post
    Is there a reason not to? Just asking. I also have aluminum carriers.
    Mar 2013
    27
    oh sorry about that I pretty new still! I have mip's all around on the rear the spacer between the bearings I never installed am I suppose to? and for the 17mm hex adapters I haven't put them on yet I was going to this weekend but am I suppose to install the bearing crush spacer aswell? I really don't want to wreck anything since I've put a lot of upgrades to make it bulletproof and being new and unsure I need advise and guidance thanks to you all
    Mar 2013
    27
    when I put on the aluminum carriers I put new bearings in if I remember correctly the bearings went in from the outsides so I didn't know what that spacer was really for since the bearings can't be pushed together
    8,238
    The spacer prevents the inside rings of the bearings pushed outwards. So yes, you better use that, also with alu carriers.
    Mar 2013
    27
    ok Thankyou I never thought of it that way it makes sense to me now thank you
    Nashville, TN
    2,077
    Yes, use the spacer.
    And on the mip hexes, a lot of people think that grub screw is to lock the hex onto the axle, like the hex pin on the stock axles. Really, it's just to keep it from slipping off the axle when you take the tire off. Use red threadlock, but that grub screw doesn't have to be super-tight.
    8,238
    Quote Originally Posted by Jws1982 View Post
    I don't know if the MIP shafts changed lately, but the ones that I use, have a round hole on the diff end side, so they definately need a screw that not only prevents them from sliding off but also from turning around on the diff shaft. The HPI pins are a good solution to secure them.
    Nashville, TN
    2,077
    +1 on the HPI pins. I use them too.
    Wales in the UK
    6,462
    They are a lot better than stock mip grubs and traxxas do some that fit but need a light trim .....peace
    Jan 2005
    24
    I installed the Slash MIPs on my Stampede with no problems. If you need help, search youtube for Stampede MIP CVD installation. In the video, the guy uses the Slash MIP part for his Stampede.
    Mar 2013
    27
    Does anyone know the hpi pin size or part number
    8,238
    See post #14.
