    Aug 2012
    35
    Hitec Servo Problem
    I have a Hitec Ultra Torque servo from like 3 years ago and I just Installed it into my 3905 and the servo horn dosent grip on to the gear. I thought the horn was stripped so I bought a new one and it turns out the horn is slightly to big for it. I've tried hot gluing it on but it didn't work. What should I do?
    Mar 2003
    Wherever the road takes me.
    37,431
    Are you using a servo horn designed for a Hitec servo? If not, that could be your problem. The Traxxas servo horn (same as Futaba) will not work with a Hitec servo; they have a different number of splines on the servo output shaft.
    19,426
    Hope this helps:
    23 Tooth
    * Airtronics: 23T
    * JR: 23T
    * KO: 23T
    * MRC: 23T
    * Multiplex: 23T
    * Sanwa: 23T
    * Spektrum: 23T
    24 Tooth
    * Hitec: 24T !!!
    25 Tooth
    * Ace/Thunder: 25T
    * Cirrus: 25T
    * Duratrax: 25T
    * Futaba: 25T
    * Hobbico: 25T (Some servos like the CS-170 uses 24 splines)
    * HPI: 25T
    * Kyosho: 25T
    * Power HD: 25T
    * Savox: 25T
    * Tamiya: 25T
    * Team Associated: 25T
    * Tower: 25T
    * Traxxas: 25T
    !!! : Some (very) new Hitec servos have a 25T spline.
    Alt-248 on the number pad =
