Thread: Speed runs
    421
    Speed runs
    I got my rustler doing some speed runs now and i need to know whats a good GPS to get oh and any help on speed runs setup is good to i have the vxl in it
    Biggest Little City In The World
    733
    small spur + big pinion + big battery = go fast You may also want to consider tires that are less prone to ballooning.
    Garmin makes a few diff models of GPS that are small. I have a older Trex GPS that i use velcro to stick on the upper chassis. Its a lil heavy buts thats ok i feel it helps keep the Rusty on the ground at high speeds. Also i think there are some apps that track speeds and and distance.
    "You just got passed by a Traxxas"
    421
    Oh I have a iPhone 4 so if you know a good one let me know
    733
    if you have a iphone4 hook up the telemetry sensors and get a TQi controller if you dont already have one. The you can see speed, battery volts and motor temps.
    421
    Nashville, TN
    2,009
    Quote Originally Posted by streetslash View Post
    With the vxl system, 31/76 gearing is really as high as you should push it. Maybe 33/76. JConcepts G-Loc tires would be a great choice. That'll get you into the 70mph range if you use a good 3S Lipo battery.
    Move the shocks out all the way on the a-arms, put in some heavier shock oil, maybe add a little weight up front under the shock tower, and cut some holes in the body for ventilation and airflow/aerodynamics. You'll be going super-fast in no time. 70mph in an RC car is flat-out moving.
    South of St Louis
    6,101
    I have a garmin nuvi that works well. Just strap it down!
    Start with 25/83 gearing and go up from there. That should get you well into the 40's mph on 3s.
