Results 1 to 20 of 20
    Apr 2013
    42
    Thermal Images - Traxxas Slash 4x4
    Did some thermal images with my FLIR E50. Slash 4x4, Tacon 2800kv, 15t pinion, stock spur, 3S 4000mah 40-50c, WP-SC8 ESC. I did the images right after I hit the neighbors trashcan wide open and took out my left a arm and ESC mount. Fun over...
    The first image is at rest, room temperature.
    Second image is after 15 minutes of speed runs. Ambiant temperature was about 70 degrees.
    As you can see, the aluminum motor mount is definitely dissipating heat.
    Easton, MD
    667
    Thats a step above a temp gun!!
    Dec 2009
    MN
    786
    Cool, no pun intended
    I like the 3rd pic that shows how much heat is transferred to the motor mount, thanks for sharing.
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    2,215
    Thats really neat.
    Apr 2013
    42
    Thanks, my pleasure. Yes, it's a big step above a temp gun. About 5k worth.
    Apr 2013
    333
    It would be cool to do it again, one with a heat sink on the motor and one with a fan on it.
    Did any one check out the wires from the motor back to the first set of connectors, after the connectors the wires were cooler. I have always believed that any connector increases resistance and therefore increases temps, so if you took those connectors out and soldered, what would the temps on those wires look like??
    Awesome post
    T.A.C
    Keep on Bashing and you will keep on Trashing
    Apr 2013
    42
    Excellent observation on the wires. I do plan on doing more with heat sinks, fans and various other configurations.
    Dec 2009
    MN
    786
    Quote Originally Posted by Team arsy car View Post
    Awesome post
    T.A.C
    I did notice the motor wires, but really wasn't surprised, since some motor wires are directly a part of the windings which would explain the heat, and cant be cut.
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    Apr 2013
    333
    Yeah I see what you mean, it is pretty cool though to see the heat dissipation, I am glad that I have fitted the alloy motor mount and a vented motor plate.
    T.A.C
    Feb 2010
    El Sobrante, Ca
    9,881
    I have one truck that has the wires soldered and one that uses connectors. You can feel the difference between the two after a run. The truck with the soldered wires seems to have better throttle response also. If you notice my signature, I am running the same motor combination in both trucks.
    Slash Ultimate El Sob special MIP King Headz 3PL
    muscoda, wi
    1,245
    i want one of those FLIR devices. just to check out my yard at night, lol.
    Temecula,CA
    2,138
    This is very cool, thanks for sharing.
    Slash 4x4, Rusty VXL(project), Slash 2wd(project).
    Apr 2013
    333
    May have to look into one of those motors El Sob, a bit off post but I am having a bit of trouble with the Hobby Wing I fitted.
    Connectors are awesome, but they do create a rise in resistance, therefore current draw, if repairing or replacing connectors on sensitive circuits (Can Bus or Digital circuits, earth circuits, or high current draw circuits) I always fit gold plated. I have noticed that Traxxas and other brands all us gold plated, there is good reason for it. Gold resists corrosion.
    Columbia, SC
    317
    Awesome post
    T.A.C
    I just don't think all the heat on the wires is created by the connectors. I think it was created by heat coming from the motor. Remember those wires connect directly to the winding and heat transfers through wires also.
    Traxxas gone bye bye!
    Wales in the UK
    6,450
    That is one awesome photo dude its great to see the heat.....peace
    392
    LOL nice I like the 3 pic , post more
    Apr 2013
    333
    Quote Originally Posted by Sierravmax View Post
    I agree with you totally, my point was that if the connectors were not there (and creating resistance) then the heat would have transferred further towards the ESC, not really sure if that is a good idea though.
    Feb 2010
    El Sobrante, Ca
    9,881
    To put my 0.02 cents in. In my setup the esc fan doesn't come on nearly as often as the truck with the connectors on it. In general every part of the motor system is cooler on the soldered truck and I have done some intensive testing. It all ends up to personal preference. Team, gold is a better conductor for electricity. It will show signs of wear on the connectors but if you use it it wont stay perfect.
    Canada
    560
    How do you like thw tacon motor? The pictures are awesome! I just wanted to know because mine juat arrived and I have to wait for more parts.
    Brushless Rips, Nitro Drips!!! BL Power FTW!
    Apr 2013
    42
    I like it. Seems to run cooler but you really have to gear up if you want to go faster than stock.
