Thread: Loosing power
    Edmonton, alberta
    194
    Loosing power
    So I was running the truck today, after I warmed it up a bit it was doing wheelies non stop and had a lot of punch off the start. After running a tank and a half through it (non stop), with no cool down time it seemed like it was loosing power. Should I be letting it cool down between tanks? Would it be cause the diff oils are heating up and getting thin? Why would I be loosing power?
    Epalinges in Switzerland
    22
    It is probably the spur gear unscrewing a bit. After you let it cool down, is it going good again? Probably not the diff oil. You maybe have a leak in the engine. Check for loose screws everywhere. The tuning of the Trx engines can also be a pain.
    Envoyé depuis mon GT-I9300 avec Tapatalk
    Revo 3.3 #5309. 25% Nitro fuel.
    Edmonton, alberta
    194
    Ya it's good after it cools down. I've completely sealed the engine. Actually it's an OS.21
    Palisade Colorado
    510
    It could be wearing out, and when the sleeve expands it will get low on compression.
    10,194
    Quote Originally Posted by Mcisaacracing View Post
    Best to contact O.S. about it.
