Results 1 to 10 of 10
    70
    slow with big block boss 302?
    I put the vxl 3500 in the stang,and it seems really slow. im using 2s lipo, and good street tires. it has the stock gearing. what can i do to increase the speed. and im thinking of putting these on it http://prolineracing.com/tires/road-...-black-wheels/. will it work?
    Alma, Michigan
    12,314
    What are your temps?
    Those tires will not fit under the Boss body.
    70
    I dont know, but it isnt hot or even that warm.i dont think the motor is getting worked out enough. i will get a new body if i had to.
    Alma, Michigan
    12,314
    With that height, you may have to get something that doesn't cover the tires... which would mean that the arms, rods, and axles may need to be swapped out to Revo length.
    Jul 2012
    Yakima, Washington
    1,440
    you should gear up if your motor is not working very hard with the gearing you have
    you could just convert to a 1/16 e revo to get those tires to work
    Mar 2013
    86
    Did you double check that the esc is not in training mode?
    70
    i have an sv3 esc, so no training mode. what gearing should i get?
    Apr 2013
    61
    Is your battery capable of powering that system? Do you have a capacitor to boots your battery?
    waterloo .on.canada
    2,292
    if memory is right stock gearing is 28/45 for the 4000kv motor(380)
    and you put in the big 3500kv motor at the same gearing?......with the same gearing your loseing 500rpm per volt.with a 2s lipo compaired to the stock mini motor your loseing a total of 4200rpm's useing the bigger motor
    so you need to gear up to compensaite for the loss of rpm....... i dont know the math
    summit /mustang /stampede-2s spc lipo
    Rotterdam, Netherlands
    8,268
    Quote Originally Posted by reod12x2 View Post
    You can multiply the motor Kv with the pinion size and keep that factor the same when you pick a different Kv motor.
    4000 x 28 = 112000. For a 3500Kv motor you can divide the 112000 by 3500, which means a 32T pinion would give the same top speed with the rest the same.
