    4
    EZ start problem
    My EZ start system has a problem where when I first hit the button, the motor spins over the engine, but then it slows down and stops. It's not the battery because I charged it fully, it's not the motor or the wires because I replaced them, and it's not the wand because I tried my friends and it happened also. I've tried a new battery. I took apart the EZ start when I changed the motor and made sure that there wasn't something catching in there. What could it be?
    Riverton Utah
    5,417
    Welcome to the forums! Sounds like the engine is bogging down with fuel, so how long does it take to start the engine?
    Is owning 25 RC's too many?... Nope!
    Toronto
    196
    Maybe something internally in the motor...binding...try spinning the flywheel by hand...afew times and feel for anything iregular, it should be easy to turn then hard, easy then hard. Maybe the motor is stuck at TDC....
    Good point Wolf.....flooded!
    Jato 3.3 Pede 2.5R Rusty 3.3
    4
    we have tried to see if it was flooded and its not flooded we took the glow plug out. and if we spin the flywheel then engie is perfect so its not stuck at TDC you can hear the engine turnover for a secon the the starter motor has a hard time spiining the engine anddoesnt turn it past TDC
    Jul 2011
    S. Jersey
    784
    How many gallons are on the engine?
    Jato 3.3, Revo .28 JL Max, Nitro Stampede 3.3
    4
    Around 2 maybe a little less.
    EDIT: I just took off the engine, then the EZ start assembly. With the EZ start not on the truck, so it can spin freely, it still does what its been doing. The wires feel really hot after that.
    Toronto
    196
    Something with the easy start then...gotta pull start?
    4
    the OWB was twisted in its socket and wasnt spinning correctly and it was wearig out the battery and the motor.thanks everyone for commenting and givig me advice i really apreciate it
    Gurley, Alabama
    797
    The one way bearing is the only thing that has ever stopped my easy-start from working, except A dead battery.
