Results 1 to 11 of 11
    USA
    230
    Tenshock sc401 and Hobbywing sc8 cogging
    What are you guys using for the timing in the programable parameters to minimize the cogging? Seems pretty bad at low speeds, luckily I am at high speeds most of the time. It is annoying though at low speeds anything else I can do to reduce the cogging? I doubt its the battery I have. 3s 5400mah 50c. Thanks!!!!!!!!!!!!!
    69
    What's cogging. I have that same setup?
    USA
    230
    stuttering at low speeds
    69
    I think i have that same problem but i really go that slow.. Lol
    Wales in the UK
    6,441
    Put the timing on the lowest setting and maybe turn the punch down a bit and that should sort it out dude.....peace
    Apr 2009
    Knoxville, TN
    2,218
    I have cogging as well with the same setup. Most people on here run the v1 motors and I got the v2 motor maybe thats the difference? i dunno
    Xerun 150A 2200kv ERBE
    Dewalt 14.4v Summit
    SoCal
    111
    I had the same setup before i replaced my sc8 with a mmp. Had cogging issues with the sc8 and even more with the mmp.
    Wales in the UK
    6,441
    It does not matter what motor it is you have v1 or v2 you just have to find the sweet spot with the settings and gearing and batteries........peace
    319
    what gear are you running? Cogging can also happen when geared high because its harder for the motor to get going
    13,609
    Did you have to solder on the bullet connectors for the motor wires? Check to make sure you did not get a cold solder joint. Also check the battery connector solder joints
    Ya can't polish fertilizer...
    Wales in the UK
    6,441
    +1 nice one rag i always forget about the soldering and its important part of it all running right.......peace
