Results 1 to 20 of 20
Thread: wheel wobble
    Mar 2013
    Colorado
    63
    wheel wobble
    So I notice that i have a bad wobble on the wheels on my 4x4, is this normal. It is not as bad when it is on the ground but, if i lift it off the ground it is bad, makes the whole truck shake pretty bad. I checked to make sure evrything is straight and tight. The truck is only three weeks old and just replaced the rear axle shafts with MIP x duty axles. with out the truck running there is quit a bit of slop in the rear wheels, the front has some slop to, but not as much as the rear. Somtimes it does it somtimes it does'nt. Is there anything to fix this or is this just part of owning a stampede.
    Dec 2009
    MI.
    848
    Sounds like your bearings are bad it's happened to me twice
    Stupid 50 character Limit!!!!!
    Aug 2012
    74
    Quote Originally Posted by TMAXX HAWK View Post
    Yup, check the big bearing inside the hub carrier. They like to shred. Also the hub carrier plastic could be withering away (this happened to me just last week)
    Norfolk, va
    1,164
    Or the Stub axle can develop some slop in it as well.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    Dec 2009
    MN
    788
    Balancing your tires can also prolong the bearings. A set of aluminum hexes, can help the trueness of rotation. None of this will help, with out new bearing. Check for bent stub axles.
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    Wales in the UK
    6,462
    Or the foams inside your tyres has gone out of shape so try and massage them back into line or its one of the things the guys have said dude......peace
    Mar 2013
    Colorado
    63
    Well, I know its not bent stub axle Just put new MIP's on and they are strait. I checked the bearings and they look good also.One thing i did notice was water inside my wheels, along with some of the glue coming apart on the wheel/tire beads. I think that might be why they are wobbling bad. I will get the water out, reglue and see if it geta any better. Do you think this could be the culprate.
    Bexhill, England
    434
    sounds like you've solved the wheel wobble mystery!
    Riverton Utah
    5,476
    Well, I know its not bent stub axle Just put new MIP's on and they are strait. I checked the bearings and they look good also.One thing i did notice was water inside my wheels, along with some of the glue coming apart on the wheel/tire beads. I think that might be why they are wobbling bad. I will get the water out, reglue and see if it gets any better. Do you think this could be the culprate.
    Ya, water filled foams and un-glued tires will FOR SURE cause the wobble you've been having. Glad you finally found it!
    Is owning 25 RC's too many?... Nope!
    Wales in the UK
    6,462
    Sorted dude water logged foam is a pain in the wheel nuts lol.....peace
    Aug 2012
    298
    I also have this issue....what's the first thing to check and how do I solve it?
    Feb 2008
    329
    There are lots of good suggestions in this thread. What have you tried?
    Aug 2012
    298
    Quote Originally Posted by jayblazer View Post
    Not sure which bearings could be causing this...I tried working the tire inserts back into shape and I looked at the bearing near the slipper so far...it looked ok
    Feb 2008
    329
    The ones at the end of the arms. Right next to the wheels that the axels ride on..
    Aug 2012
    298
    Would they need replacing so soon? I've only run maybe 12 packs thru the truck....No lipo yet
    How can I tell?
    Nashville, TN
    2,078
    12 packs is enough to get bad bearings, especially if they got wet.
    Aug 2012
    298
    what is the best brand to replace them with?
    Nashville, TN
    2,078
    There's lots of opinions on that. I clean and check mine fairly often, so I just go the cheap route. I buy the cheap rubber-sealed ones on eBay. They've always worked great for me.
    USA
    571
    Boca bearings are one of the best out there, but they are baller bearings. I will repeat that again, baller bearings.
    Avid bearings are second best IMHO.
    Btw, here's jang's 'Spensive Boca Bearings update:
    http://www.youtube.com/watch?v=XjNWRvikF6I
    I want an avatar... 3000 posts here we go!
    Wales in the UK
    6,462
    And look at Acer racing bearing they do a full bearing kit for the pede 4x4.......peace
