Thread: Servo
    69
    Servo
    Any experience with the corona DS339HV servo, or any corona servo? Does it work with the older traxxas 2.4ghz TQ radio?
    Feb 2002
    8,078
    if it is digital it should work fine....
    however, hv versions are for high voltage applications.... your bec on your radio system doesn't put out the power they need to operate correctly, running one wont hurt anything -- but performance will be severely diminished
    http://www.youtube.com/watch?v=3nhgfjrKi0o
    69
    The site says that operating travel is 40 degrees, is that fine?
    It is 33mmx34mmx17mm, will it fit well without modification
    Alma, Michigan
    12,313
    Here are the specs on the stock servo:
    Modulation: Digital
    Weight: 0.67 oz (19.0 g)
    Measurements: -LxWxH- 1.200.551.10 in (30.514.027.9 mm)
    Torque @ 6.0V: 41.7 oz-in (3.0 kg-cm)
    Speed @ 6.0V: 0.11 sec/60
    Bushing: Plastic
