Results 1 to 20 of 20
    Feb 2013
    Maryland
    141
    Merv Makes Clicking Sound. Please help!
    Hi guys today I was playing with my 2 new 2s lipos in my brushed merv. I accidentally ran it into a trucks's
    tire and now it make this weird clicking noise. It sounds like it is coming from the back end of the car, which
    is weird because it was the front end that hit the tire. I'm not totally sure where the noise is coming from
    though . I didn't take it apart but nothing appears to be broken. When I apply the throttle all for wheels spin but it makes a strange clicking sound. It even clicks when I roll it across the ground. Dis something just get jostled loose?
    Here is a link to my video that shows the clicking noise. Sorry about the quality. It was made with my cell
    phone in a hurry.
    [URL="http://www.youtube.com/watch?v=fKOAZQy1w-8"[/URL]
    so cal
    9,244
    You could have stripped the rear diff
    When the car stopped quickly the rear tires were spinning and had to stop suddenly also
    Feb 2013
    Maryland
    141
    Is there any way to tell without taking it apart, or should I just get r done
    162
    If its clicking... It's the diffs.
    Don't be affraid to take your truck apart, you can't break what's already broken.
    Sent from my ADR6350 using Tapatalk 2
    Feb 2013
    Maryland
    141
    Quote Originally Posted by DogMilk View Post
    Yeah I know. I just broke my chassis a couple of weeks ago. Do you know the part number for the differential?
    162
    Quote Originally Posted by 007A99 View Post
    Traxxas 7078 i believe. You should take it apart first and make sure.
    Sent from my DROIDX using Tapatalk 2
    Feb 2013
    Maryland
    141
    Ok thanks! I was not expecting it to cost $20 though.... i found it on ebay for $16.. Do you know of anywhere that has a better deal?
    so cal
    9,244
    All you need is a 7079 ring &pinion and buy some associated 21141 shims to shim it
    Feb 2013
    Maryland
    141
    Oh THANK YOU! Does it just slide onto the differential or what?
    so cal
    9,244
    you have to take 3 screws out -it's part of the whole unit.you will have two plates -one on each side with spider gears in the middle. you will understand when you see it. you will also need some 50k diff oil to replace the fluid
    Feb 2013
    Maryland
    141
    Is the 50k diff oil the stock oil or no?
    Mar 2013
    Denmark
    27
    The 50k fluid is standard and is pre-filled in the diff, but sends too much of the power to the front wheels.
    I would recommend using a higher weight fluid, and is using 100k myself.
    so cal
    9,244
    50k is stock it the front and 30k in the rear. i usually run 50k in front and rear
    Feb 2013
    Maryland
    141
    Ok thanks! I noticed when I took the motor off of the car, the clicked stoped. As soon as I put the motor back on, it started again. What is the name of the gear that connects to the pinion gear on the motor? Is this the spur gear? I noticed that it had 2 spots on it where about 5 or 6 gears on each spot were stripped (they looked like they had been smashed down). could this be the source of the clicking?
    so cal
    9,244
    Yes the spur. And yes a bad spur can slip and make a clicking noise
    Feb 2013
    Maryland
    141
    How many teeth does the stock spur have? Should I use a lower tooth count since I run 2s lipos in parallel? Also, should I get a metal spur or stick with plastic?
    so cal
    9,244
    Stick with plastic! Stock is 50t
    Gearing depends on engine and esc temp, tire size and terrain
    Feb 2013
    Maryland
    141
    My esc and motor never gets hot. It barely gets warm.. I have the stock tires and I do all terrain driving.
    Alma, Michigan
    12,314
    Smaller spurs make you go faster... and are harder on the system.
    And another vote for sticking to plastic.
    Feb 2013
    Maryland
    141
    Ok, so ill stick with the plastic 50 tooth spur
