Results 1 to 12 of 12
Thread: what servo arm
    206
    what servo arm
    what servo arm would i need for the hitec hs 82mg
    ebay link???
    thanks in advance
    Alma, Michigan
    12,314
    so cal
    9,244
    This will work http://www.ebay.com/itm/Hitec-Standa...item232699d48b
    Might have to shorten it a little but that's not hard
    Jul 2013
    7
    I also have the same question but with a twist, I recently purchased a Hitec HS-82mg. It appears to work fine but the servo horn looks so weak in comparison to the stock Traxxas servo horn from the stock servo. I recently purchased the horn mentioned above however I'm still using the stock Traxxas servo hardware and the stock servo saver. What issues should I expect if I use the metal servo horn as mentioned above if any? Should I now purchase a metal servo saver or am I good?
    It is for a 1/16 MERV and I just bash around with my son but let it off the chain at times. I'm running stock motor with 2, 2s Lipos.
    May 2009
    Edmonton, Alberta
    3,663
    I just bought a HR Servo horn to fit the MERV.
    VXS24SH02 clicky
    24t bolts on to the Hitec HS85/82 no problems, great fit too as its made for the truck.
    Alma, Michigan
    12,314
    Aluminum horns are ok... but it has been proven that the aluminum servo savers actually do the exact opposite; they fry your servo from making it work too hard... even aftermarket ones.
    Jul 2013
    7
    Thanks Cameron, loks badass too...better than the white, feeble Hitec arm! for $6.88, I'll take that one too
    May 2009
    Edmonton, Alberta
    3,663
    Made for the traxxas 1/16 so it accepts the stock link with no mods too. I think they make a 25t as well as a replacement for the stock horn too.
    Send via most likely stolen wifi...
    Sep 2013
    28
    So what can we do to get more durability into that part? I have had three breaks, and not from abusive driving. I was thinking about replacing the part that keeps breaking (the part where you bolt up the linkage from the servo). I am already working with an aftermarket metal gear servo. Since you have to buy the whole steering setup to get the one piece I need, I don't want to keep doing that.
    Alma, Michigan
    12,314
    Replace the part at the top right with aluminum and keep the rest stock:
    Except for possibly the "Y"...
    That would make it so the slip joint is not aluminum on aluminum, but aluminum on plastic.
    Sep 2013
    28
    I was thinking similar. Will give it a try.
    Sep 2013
    129
    I am not having bad results with the HR servo saver, using the stock spring and setting it as loose as possible.
