Thread: Bulkhead?
    Mar 2013
    Bulkhead?
    i broke my bulkhead and installed a replacement however it was an extremely tight fit and now, before the bulkhead broke i was able to do wheeles no problem however now i have trouble barely getting wheels off the ground. would the bulkhead be the issue in this power problem??
    Jul 2012
    Yakima, Washington
    1,440
    it sounds like your slipper clutch was loosened, just tighten it back up
    Feb 2002
    8,469
    if nothing else changed, it could be..... you might have some binding
    TRUMP 16!
    so cal
    9,244
    What was tight about it?
    To adjust the clutch tighten the nut until it stops then back off 3/4 turn and try it again
    recalculating...
    590
    I'm going to agree you might have some binding going on in the differential, check the slippe first because it's easy access, but if it's the diff take it all apart and see if you can re-assemble it without binding, I know in the rear end if you use screws that are too long for the toe links they will go through and begin to push against the differential.
    I like turtles.
