Results 1 to 11 of 11
Thread: correct gearing
    29
    correct gearing
    I have taken the stock wheels and tires off the rally and im now running 2.8 tranchers mounted on desperado wheels. i have noticed since then that motor gets really hot very quickly. Should i re-gear? and if i need to what would yall recommend?
    thank you.
    7,173
    What's your installed gearing, stock?
    Stock 13/54
    Optional 19/54
    This will help us help you with what your gearing needs to be.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Buffalo NY
    1,330
    +1 Digger. What's your current setup, sir? And welcome to the forums...
    29
    im still running the stock 13/54 and running a 2s 65c lipo.
    29
    here is the evolution of my rally so far.
    29
    that is also my first paint job, just finished it about 30 mins ago.
    Buffalo NY
    1,330
    Quote Originally Posted by protonvxmatt View Post
    Nice paint job!
    You need to back it down 2 teeth on your pinion to control temps. You'll accelerate a bit faster, but with slower top speed. Here's the one you need:
    http://www.ebay.com/itm/2-Traxxas-11...item20cef2aa54
    If you haven't changed your pinion before, check with us first. It's easy.
    P.S. -- DiggerPede *might* have a different suggestion; if that's the case, listen to his advice over mine!
    7,173
    First off clean conversion man!!! Nice paint. Many will suggest you move to the Slash 4x4 LCG area. I say you are good to go here.
    Quote Originally Posted by zippogeek View Post
    Nice paint job!
    No way man!!!. You're totally spot on 'zippo'. I'd go back 2 teeth to 11T and then check temps. You went from way smallish tires to humongous 2.8" trenchers. You picked up some speed when you went larger to.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    29
    does going down 2 teeth greatly impact how hot the motor gets? im still new at all this and learning as i go.
    thanks guys
    7,262
    any time you go bigger wheels/tires you counter act it by going either smaller pinion or bigger spur.
    29
    I'm also considering upgrading the motor and esc down the road any rcommendations? I'm primarily using this car for bashing. i,e no racing. I want to be able to still run in the snow. Do i need to find a water proof motor/esc or is that something i can do to make which ever motor/ esc water resistant?
