Results 1 to 22 of 22
    392
    Angry have big problem
    I put in my 2s lipo into the car turn on and try to go at the start always the clicking noise and then stop. full power and noting a esc makes this quite beeping noise when i press the trigger, try to move it by hand with full power on and it is like the brake is turned on , but i let go off the trigger it is fine when I push it
    when I keep the trigger on full power after couple of sec the wires get so hot and start smoking (the wires)
    tried different battery and same
    when I put it in the air some times it starts working back but for a minute
    Easton, MD
    680
    Are your motor wires connected correctly? If so lift the motor off the spur gear and try again to see if the motor turns. If so, it might be in your drivetrain.
    392
    wires are correctly connected / when I lift my motor it is fine but when there is more weight on it it doesn't work
    Quote Originally Posted by briandee View Post
    69
    So it won't go? Mabey your pinion gear slid of and isint on ur slipper? That's what happend to me my set/grub screw came off and the pinion gear slid and my truck wouldn't move
    392
    the pinion is fine
    Quote Originally Posted by Sandford98 View Post
    Philly area
    507
    Sounds like your motor is shot. Mine did the same thing. Mine made a funny sound when on the ground. When in the air it spun fine.
    Princeville, Québec
    958
    Quote Originally Posted by robdog View Post
    +1, mine did that too!
    Summit RX8/1550kv-Slash4x4 MM2/2400kv Twin-V Merv.
    Sep 2010
    the giant boot. Anybody?
    2,726
    Magnet unglued from the rotor. If it is within the 30 day warranty they will replace it for free. Maybe a good time for an upgrade on power system?
    392
    I will send a video about this problem,
    and I think I will have to upgrade to mamba monster 2 or tekin rx-8 system
    392
    here is the video that I have a problem with
    http://www.youtube.com/user/rustler1999929?feature=mhee
    please watch full video
    Princeville, Québec
    958
    The motor has burned, the copper coil is melted inside, and causes a short circuit. What causes the problem of wire overheating. That problem happened to me two weeks ago.
    392
    sooo should i GET mamba monster 2?
    Sep 2010
    2,726
    If you do that you will also need;
    MIP or Tekno driveshaft's
    Kingheadz motor mount and 5mm bore 32p pinion gear's
    Aluminium hex's
    Lipo's of at least 3s, but 4s is the sweet spot.
    Grafenwoehr Germany
    1,304
    Lipo size depends on what kv motor you get...slash 4x4 - 4000kv 4pole 2s = sweet spot.
    360
    Quote Originally Posted by Emaxx1991 View Post
    4000kv motor is the sweet spot of a slash? I beg to differ.
    -Slash 4x4 MT 2000kv
    -Slash 4x4 MT 2100kv
    44
    Pretty sure he meant 2s is the sweet spot of a 4000kv motor.
    Grafenwoehr Germany
    1,304
    ^^^^^yes...
    392
    any one could help me find a good price on ebay for mamba monster 2 or just the esc because I probably I will buy the motor from tower hobbies .
    San Jose, California
    125
    My sons Slash was acting the same way a couple weeks ago. Turned out to be a loose screw. When you remove the rear bulkhead and slipper/spur assembly, there is a small screw going up through the chassis and into the motor mount. This screw came loose and was contacting the spur gear.
    May not be your issue, but its something quick and easy to check.
    -Mike
    Two Stampede 4x4's and Two Slash 4x4's
    392
    hello could this be the problem?
    http://www.youtube.com/watch?v=TwfZEjYkpd4
    and can someone tell me what he is saying because i can't really understand him
    thanks
    392
    yES I FIXED IS HERE IS A VIDEO LINK
    http://www.youtube.com/watch?v=6USzQjGox4I
    THANKS TO ANYONE WHO HELPED
    Easton, MD
    680
    Glad found the source of the problem. First thing to check: Is it plugged in?!?! Just kidding. Have fun!!
