Results 1 to 17 of 17
Thread: venom help
    Mar 2013
    wa
    138
    venom help
    have a venom 4200 running a 23 90 does this sound right going from 3500 to 4200 motor? running stock tires on a mixed sand bowl/loose big track 30+ mph powerlides (controlable)
    Mar 2013
    wa
    138
    can anyone help? im new to brushless dont want to hurt motor or esc
    Lafayette,LA.
    712
    You need to pay attention to motor temps. Very important! Invest in a cheap temp gun from lhs. I don't let my motors get over 160deg. You can use the touch method just be careful as these motors can burn if temps are high.
    Sent from my MB886 using Tapatalk 2
    Mar 2013
    wa
    138
    can hold motor for around 10 seconds after 4/8/15 min or so just looking to see if 23/90 is close to what it shoild be going from 3500kv to 4200kv only have 16p 23p / 86s 90s
    13,774
    If you can hold your finger on there for 10 sec, I am pretty sure its not getting over 140, even if you have superman fingers. You are probably safe, but pick up an ir temp device to be safe. It would suck to ruin a $100 dollars worth of equipment because you did not pick up a 15-20$ temp gauge.Harbor Freight also sells them pretty cheap.
    Ya can't polish fertilizer...
    Mar 2013
    wa
    138
    temp isnt my prob just want setup ( ring/pinion)to be efficient like i think traxxas did on velineon
    Michigan
    7,731
    Is the 4200kv a 2 pole,or 4 pole?
    Mar 2013
    wa
    138
    atomik venom system 80a esc with v550 4200kv 2pole
    Michigan
    7,731
    A 2 pole will run hotter,and has less torque than a 4 pole,you might want to watch you temp's close for a bit at 23-90.
    You should have a 20 or at least a 22 tooth pinion,in case you find heat trouble.
    The higher the kv rating,the warmer the motor might get,geared to high.
    On 2s the velineon has a top speed of around 35 mph with 23 90,the 4200 will run about the same speed at 20-90.
    I say 2s because you said track,any real track has a 2s limit.
    Mar 2013
    wa
    138
    well its a track at my house and is a 2s limit with stock tires any motor and only gears that are from copany trucks came from big nice track with tight turns/ sweeping turns/straights right before turns so traction is all driver put 86s on with 23p seams good after whole battery could hold it forever
    Mar 2013
    wa
    138
    well got a sct 3800kv (with built on fan) lve it so far. im running 20/90how fast you guys think its going on 2s ? and how much if i run 23/86 im an old new again to electic
    Grassie Ontario Canada
    3,138
    Quote Originally Posted by superslasher View Post
    Wait so you bought another system?
    Well it won't be too fast
    I ran 25/83 on my slash with that set up
    Mar 2013
    wa
    138
    yes my son took venom out ran a 3s in our sand bowl need i say more . i feel its going around 30 and maybe 40 on 3s with 20/90 what you guys think?
    Michigan
    7,731
    I think with 3s on a track,the hole truck wont last long. I've said this many time's,I have 24 lipo's,one is 3s,and gets used once or twice a year. With out great throttle control 3s is just to much for a slash,and more so on a track.The gearing is fine at 20/90,(4.5),but there is a reason most all sc tracks have a 2s limit.
    With that gearing on 3s the slash is capable of 45 mph,but it's been my experience that a two pole motor on a track with 3s wont last long.
    Mar 2013
    wa
    138
    its a castle sct 4 pole dont use 3s much just only to prove crap with buddy bashers. was just trying to make a point that a 800 dolar trucks couldnt beat mine with my new sct set up and all together i only spent around 400 for truck/sct/and power strokes
    Oklahoma City, OK
    2,690
    the venom 4200 motor is only rated to 2s.
    If you're using a VXL-3s ESC, you should be fine, according to traxxas, there is no motor limit. Unless it a 4 pole motor, then it wont work with that ESC at all.
    You're gonna really enjoy the SCT 3800 combo - tough as nails. i run mine on 2s - prime time!!!
    "RED"
    Michigan
    7,731
    Hope you have the mmp esc,the sct castle wont take 3s well either,I run three castle systems.
    And am quite aware of their limits.
