Results 1 to 13 of 13
    Australia
    419
    Wheel nut problem
    Umm... My wheel nuts too tight, I can't get it off! Any tips on how I'm supposed to get my wheel off?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Jul 2012
    A long time ago in a galaxy far far away...
    465
    Hold the wheel and get some pliers. Grab the wrench perpendicular to the side you are using, its a 4 way wrench so it can hold on. Then just attach it to the nut and it should come out.
    Drive. Crash. Fix. Repeat.
    Australia
    419
    Thank you for your help! I'll try it later
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Australia
    419
    Sorry guys, I've been so busy with first year of high school I haven't had the time to reply to this old thread. I tried your suggestion funny but its just stripped from all the times I tried to get it off, so now I have stripped nuts that are really tight. I'm able to sacrifice the wheels, in fact they're going in the trash when (or if) I get them off.
    Cheers, Hammer
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    1,334
    Just go to your local hardware store and get a socket for stripped nuts.
    Or you could try a little heat and a small set of vice grips
    Australia
    419
    Quote Originally Posted by Crock View Post
    The thing is, even if they weren't stripped, and I got a socket for stripped nuts, I wouldn't be able to turn it. Do you guys think it would be worth it to cut the wheels off?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Apr 2013
    Poland
    180
    You could dremel or file the nut from two opposing sides, so it could be grabbed by some pliers and the try turning
    1,334
    are the hex's stripped in the wheel as well? you should be able to grip the wheel by hand tight enough to get the nuts off.. A little heat will help soften up the lock tight that is probably on them. I thought i was going to break something on my summit the first time i took them off.
    392
    the stripped socket if its the one I'm thinking of will grab the nut, then you use a socket wrench attached to it, no way you aren't removing those nuts with a socket wrench if the stripped socket grabs the nut.
    The alternative is to see if you can grab them with a needle nose vicegrip.
    Australia
    419
    I'm thinking ill just borrow my grandfathers metal file, and file the nuts right off. Do you reckon this might be worth a try?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Apr 2013
    Poland
    180
    If you dont mind ruining your rims (tires could be saved I guess ...) - you could use a lighter and melt the plastic away from beneath the nut??
    Australia
    419
    I don't want to damage the a arms or anything else, so I think ill try and file the nuts off.
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Sep 2011
    Iowa City, Iowa, USA
    4,316
    Hold a soldering iron on the nut to soften the plastic. Then use some pliers to give it a twist. Maybe even try some penetrating oil.
