    Mar 2013
    California
    7
    ez peak plus says 'full' when done charging
    1. after my batteries are fully charged the chime goes on, I know thats normal but my question was when i press stop the chime is still on and like seconds later the chime turns off and I can go back to the battery type display screen, basically when i press stop, the chime still stays on for a couple seconds, is this normal?
    2. does the ez peak plus have an on/off switch, or do you simply disconnect it to turn it off?
    3. I have an ez peak plus, and traxxas 5000mah 3s packs, how do I set the storage mode for these batteries if I wanna store them for a couple days?
    thanks
    Riverton Utah
    5,381
    Welcome to the fourms!
    1:When I hit stop on my EZ Peak Plus, the chime stops the secound I press stop, so I'm not sure if that's normal.
    2: It doesn't have a on/off switch, you just plug it in to turn it on, and unplug it to turn it off.
    3: Did your charger come with the manuel? The manuel has all the info you need in it.
    Hope this helps!
    The Wolf is not concerned for the sheep's opinion
    Mar 2013
    California
    7
    thanks for the info! ill be sure to read more about it on the manual, im new to the forum also, so I thought id ask a few questions, cheers
    Earth
    505
    I don't a Traxxas EZpeak but wanted to say Welcome to the Forum!
