    Arizona
    119
    Slash 2WD Slipper Clutch Setup
    i was wondering what the stock slash slipper clutch positons is (how many turns) and what the recommended setup is. i'm not sure if what i am using is the best setup.
    Michigan
    7,728
    Traxxas tells you to start with one full turn out and tighten or loosen from there,It depends on the track for me.
    The slipper should lock in with in two feet.
    This will help save your drive train,to tight,will put more stress on the drive line.
    Arizona
    119
    how many turns do you loosen it usually?
    Michigan
    7,728
    It depends on the track,very rough sct's with a lot of jumps, I will run one and a half turns out, sometimes on the big flatter oval,I will run 1/2 turn out.
    Quote Originally Posted by sixty2 View Post
    how many turns do you loosen it?
    Arizona
    119
    cool, i was doing about 1-1.5 turns and wasn't sure if that was normal. thanks.
    Michigan
    7,728
    No problem.
    As you go you will find out when its to loss or to tight.
    Feb 2013
    19
    is it slipping?
    I can never tell how much the clutch slips in use. Alternate method i've seen is to turn it on, hold the rear wheels, and give throttle. Loosen until it slips, then tighten until it just lifts the front end.
    Chino Hills,CA
    305
    Quote Originally Posted by brik View Post
    Yup that's how its done. Turn it on have someone hold the wheels and give it throttle and I adjust it if its more then 2 inches wheel lift.
    2wd slash, PL LCG, CC 3800, Powerstrokes, S6040
    Michigan
    7,728
    That sounds like a good idea,but what about loss dirt tracks?
    It seems like that would be a bit tight.
    But I think I'll give it a try,got nothing to lose.
    Thanks for the idea guys.
    Quote Originally Posted by TheDonJuan View Post
