Results 1 to 7 of 7
    Sep 2002
    Arizona
    322
    Wheels - 17mm Hex Wide Offset
    Hey, if you are using a wide off set wheel with 17mm hex and you did not have to cut or modify the wheel's bead, can you let me know what you used?
    Portland OR
    381
    Good luck, call a wheel maker and talk them into making them. I think there is a market for them.
    The Mitten
    1,685
    I wanna say if anyone does, it will be Pro-Line, RPM wide offset?
    Everything overpowered...
    19,434
    Quote Originally Posted by garywi View Post
    Wheel's bead or tire's bead? Which tires are you asking about?
    Alt-248 on the number pad =
    13,773
    If you have 17mm hex adapters, ofna mt3 splits are great 3.2 wheels. You can actually stretch on a set of 2.8's on them, but you need some strong hands...
    Ya can't polish fertilizer...
    Dec 2009
    MN
    788
    Quote Originally Posted by braaap58 View Post
    I think Its time Pro Line steeped up to the plate, and release a 17mm desperado 2.8 with a TRX bead-lock. Let the e-mails begin! To the OP currently you will either have to mod the wheels or your tires to make it happen.
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    Jun 2010
    Springfield, Ma.
    3,366
    I think the super low profile of a trimmed up 2.8 is much more stable, its worth the work it takes! Stretching the tire is more work than cutting and ....... you have a bigger than intended tire, more likely and able to balloon, the only upgrade with the stretched set is the 17mm hex. In this instance, taking the time to trim the wheels/tires has significant benefits.
