Results 1 to 17 of 17
    Minnesota
    303
    does this grease work for diffs? pics
    I still need to change the grease in the diffs of my rustler vxl and i found this in my garage. does it look like it would work?? thanks guys!
    Philippians 4:13
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,508
    Virtually any grease will work. The thicker and heavier a grease is the more it will make the diff act like an limited slip diff and the longer it will last before it will need re packing.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Sep 2012
    Ventura, CA
    106
    That's the tube from Harbor Freight, isn't it? I think that's lithium grease. You're supposed to use silicone grease inside the diff.
    Aug 2007
    So Cal
    21,508
    Quote Originally Posted by altidude View Post
    I've used every kind of grease I can think of and the only difference I can tell is how tight it makes the diff and how long it lasts. I honestly dont think it matters if it is silicone or lithium or some other base materiel.
    BlindMan Racing
    SPC Lipo Power
    Nashville, TN
    2,072
    +1 it doesn't matter. Use whatever is thickest. I have a tube of lucas red n' tacky that I use.
    Sep 2012
    Ventura, CA
    106
    Thanks Dad and Jws. That makes things simpler!
    Minnesota
    303
    Sounds like i got the clear i think ill start tearing it up. hope i do it right, ive never takin one of these apart before, youtube should help
    Philippians 4:13
    Minnesota
    303
    how often do you usually change the grease??
    Philippians 4:13
    Nashville, TN
    2,072
    I just do it every few months out of habit. You could go longer I guess.
    Aug 2007
    So Cal
    21,508
    Quote Originally Posted by Traxxas117 View Post
    Depends how much you dirve the truck. When I was driving my Rusty on a daily basis I would re pack the diff every 3 or 4 weeks and that was stretching it.
    BlindMan Racing
    SPC Lipo Power
    Minnesota
    303
    i drive my trucks pretty hard,every day,a few times a day. what grease lasts the longest then??
    Philippians 4:13
    Herrin, Illinois
    226
    +1 on the Red N Tacky. I use it on everything. Works great.
    Sponsored by Sugar Mamma Racing aka The Wife O.o
    Minnesota
    303
    can i use lithium grease inside the differential gear? so i would be using it for everything in the tranny.
    Philippians 4:13
    Jan 2008
    South Jersey
    8,404
    I think you're referring to sealed diffs. They usually take silicone fluid instead of grease. The problem with the stock Traxxas diff is that it's not sealed and silicone diff fluid will end up inside your trans, running out of the out drive bearings, or in extreme cases out of the hole in the bottom of the trans.
    13,766
    That leaking diff lube will also cause a lot of drag in the gearbox, which will add heat to your motor/esc, lower run times, and decrease performance...
    Ya can't polish fertilizer...
    Jan 2008
    South Jersey
    8,404
    On the bright side, it will increase drag brake.
    Minnesota
    303
    I put lithium grease in the biggest gear that's in the transmission. Is that okay?
    Philippians 4:13
