Results 1 to 15 of 15
Thread: Cleaning
    185
    Cleaning
    What do you guys do to clean your merv from dirt and nasty gunk? Do you use motor spray or WD40? What about lubricate the bearings? Do you use Tri-Flow or light machine oil?
    Watch Out!!! My merv is a little green Hulk.
    Buffalo NY
    1,330
    WD-40 = "Water Displacement." Fights rust and dirt really well! Either Tri-Flow or light oil would work fine for the bearings.
    Riverton Utah
    4,490
    Yep. But, IT"S NOT A LUBRICANT! You need to use a true oil, not WD-40. 3 in 1 oil works, in fact any oil used in cars like motor oil will work also. Just some work better than others. To clean the gunk off, I just run them in the snow. I wash the crud of in the sink, then I wipe it down with a towel. Works great. Just my .02 cents.
    Summit Rustler Sl2sh TMaxx Pnde Slayer Sl4sh
    Jul 2011
    yankees suck
    88
    i use my lil air compressor the blow the junk off, esp i just ran in the wet. a dab of wd40 on metal parts n screw heads will stop rust.
    so cal
    9,244
    For my other then ceramic bearings I use acer sin oil .made for bearings and works great but they should be cleaned first. I use a bearing blaster with motor spray
    holliston massachusetts
    122
    I have a 2 gallon air compressor that I use to blow all of the water and gunk away my only complaint about is that 2 gallons is not quite enough air I think a 6 gallon would be better
    Riverton Utah
    4,490
    Ya, I've got a 40 gallon, so I'm covered. The bigger, the better. I forgot to add that blowing your car off works great also.
    Ontario
    989
    "simple green" spray and a toothbrush works amazing
    What's a coffee if it aint Irish
    Sep 2004
    Woodhaven, MI
    2,069
    I clean my MERV with snow
    Welcome to Traxxas.com Yes, EVERYONE here IS a Pro Racer.... [/sarcasm]
    Oct 2012
    New Zealand, Christchurch
    82
    I fill up the kitchen sink and scrub it with a sponge and soapy water...
    Sent from my iPhone 5 using Tapatalk
    Traxxas E-Revo Brushless 1/8
    2x2s 40c LiPos 24/54
    Feb 2013
    Auckland, NZ
    208
    i use my compressor to get as much crap off, then assorted old paint brushes to get the rest.
    if something is really stuck, i crack out some petrol and leave it in there for a bit... not sure what the health and safety cops would say to that
    Aug 2012
    Riverton, Utah
    228
    I spray my merv down in the sink then put it in front of a heater for a couple hours rotating it a few times
    MERV, Broken Alias.
    Earth
    429
    First, i shake it upside down take out the motor because mine is brushed take it to a sink and wash it with hot water then i take it to the garage and spray it down with my air compressor and then relube it with 3 in 1 oil and some bearing grease each and every time after a heavy run!
    Oct 2011
    Vermont
    725
    Quote Originally Posted by TQi View Post
    +1 on simple green that stuff is great combined with an air compressor and you have a clean truck!
    You ain't bashin unless your crashin!!
    Aug 2012
    Alberta Canada
    909
    WD 40 is good to clean away water, its what it was initially invented for. ( de ice planes) only thing i find is that you need to really wipe away the oil or fine dust collects much faster. I've been using carb cleaner and really like it. its super cheap and the can has a lot of pressure, I then use my air compressor or a rag to wipe the dirt off!
