    The Mitten
    1,676
    Need advice on MMP on my Rally
    I need some advice on what setting I should run on the MMP with the stock VXL motor?
    Thanks in advance.
    Everything overpowered...
    7,263
    can the MMP run a 2 pole? i guess it can but there might be some weird take off or cogging, i dont know.....i'm just guessing
    humay has left the building, peace.
    13,593
    Use default settings to start. Change the lvc from 3.2v to 3.5v for lipo batteries. The mmp will run a 2 pole vxl motor just fine.
    Get a castle link so you can fine tune the brakes and many other options.
    Ya can't polish fertilizer...
    7,173
    +1 to rag
    I've been running an Sv2 paired with the 3500kv VXL for a little while now. The MMP is just a better overall controller with a higher battery limit. Which you wont need with this motor. Just remember the VXL has 3.5mm bullets and the MMP has 4.0mm bullets.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    The Mitten
    1,676
    I have a field programmer/link. And rag that is exactly what I was looking for. I knew it could run the VXL, I was just needing the settings I should run. It was used, so what are the "stock" settings I should put it back to? (If its changed up)
    I really like how the SV2 is performing in the 1/16 and I just traded my spare 2650 for a MMP.
    And Digger, thanks on the info, luckily I was prepared and I have the Great Planes adapters =)
    The Mitten
    1,676
    Alright, these are my settings:
    Auto Lipo Vols/Cell: 3.5v/cell
    W/ Reverse
    Normal Direction
    Beep Enabled
    80% Brake (was at 50% I put it up a bit since the vxl-3s gives 100% but i didnt wanna go all the way.
    Drag Brake disabled
    Transmitter Calibration:
    Full Reverse: 1.048ms
    Neutral: 1.479ms
    Full Forward: 1.910ms are these good bad? or is that jus how long it took to hit those during programming?
