Thread: Piston & sleeve
    Feb 2010
    Brewster ma.
    701
    Piston & sleeve
    I cannot push the piston through the sleeve. Should i not even bother reasembling this ?
    Keep the shiny side up!
    10,347
    It's supposed to go through the bottom, not the top. Note there are no piston rings; this is because the sleeve is tapered to pinch the piston as it nears the top.
    Feb 2010
    Brewster ma.
    701
    This is from bottom to top , but will not push through.
    10,347
    Again, you are not supposed to push it through the top. If you get the piston flush with the top of the sleeve the piston and sleeve are spent. It needs to go through the bottom.
    Feb 2010
    Brewster ma.
    701
    Sorry , i guess my question was not clear. I was not sure if the piston went clear through the sleeve it was spent. It clearly passes the top of the sleeve. Thank you.
    New York State: Snowbelt
    747
    Yeah, take it from a dummy like me. If you get the piston out through the top, your in bad shape
