Results 1 to 9 of 9
    25
    Bad sound from a place
    Today my erevo started to make bad noises, it sounds like some gears is wrapped, but i have checked both diffs and the gear-box and still not located the noise, the sound isnt there constant, only when i give full throttle,
    Any idea what this can be?
    Sent from my iPad using Tapatalk
    9,244
    Check the clutch
    25
    What can be problems there?
    9,244
    Could be worn an slipping.
    25
    Ok, so just drive and see? I checked the temp around the clutch/motor-mounth, it was hot, anything to do? Or just drive and have fun?
    9,244
    Try letting it cool for 15 minutes then adjust the clutch
    Tighten nut all the way down then back off 1/4 turn
    4,840
    if it keeps doing it after doing what 50togo said to do tightening then check slipper pads perhaps worn out like 50togo said as well and need replacing they are not too much either.
    DEU 8:18 ESV
    25
    I drived my car yesterday, and the noise was higher, i see now that the outside wheel on rear-diff is broken now. So i just have to order a new one
    3,338
    If its a grating sound could be one of your diffs is on its way out.
    Rock n Rolla !
