    469
    Controller blinks
    I got a 2.4ghz radio and its the tq with the flip antena the car works and so does the radio but the remote blinks the entire time?.fresh set of batteries to.
    Alma, Michigan
    12,316
    What color?
    469
    Green its just like a slow blink but condistent..
    Everything works good though. On the esc of the car its lights green to. Until u push forward or reverse the light goes away. But everything works great..
    469
    Consistent i meant.
    Alma, Michigan
    12,316
    The ESC light is supposed to go off when in the middle range of throttle. It is supposed to relight when at neutral, maximum forward, and maximum reverse.
    Transmitter LED Codes
    Solid Green = Normal Driving Mode
    Slow Red = Binding Mode
    Fast Blinking Red = Link Error/Failure
    Blinking Red = Low Battery Alarm
    Blinking Green = Neutral Out of Range
    469
    So what does neutral out of range mean
    469
    Hey guys i found a paper in remote with instructions i set to factory defaults and all is good now. The esc is green and on full yhrottle or full reverse it turns green again and the remote is just solid. Thanks
    Alma, Michigan
    12,316
    Glad you got it figured out!
    Salisbury, NC
    633
    Quote Originally Posted by brandon32689 View Post
    When it was blinking green, it was trying to tell you throttle trim was not set right. When this happens, the right knob defaults to that so you can fix it. Adjust it until its constant green, then hit save. Turn everything off/on and that's all you need to do and the knob will default back to whatever you had it set to. I just had to go through that when I got a new transmitter.
