Results 1 to 3 of 3
    12
    engine rebuild 3.3
    Relatively new to the sport, I rebuilt a 3.3 the other day (new sleeve,piston,con-rod) and didnt realize that I had used air filter oil instead of the after-run oil (as the manual stated) while reassembling. The engine is shelfed for future use, but should I be concerned about the air filter oil?? Do I need to disassemble and reassemble the motor again??
    11,970
    That sticky mess may cause issues. Do it right and disassemble and clean up.
    12
    thanks, will do
