Results 1 to 14 of 14
    9
    Motor gets hot with 2s lipo
    I'm using Venom 2000mah, 7.4v, 20c battery's (one at a time) and after barely 10 minutes of driving hard the motor gets super hot to the touch. any idea's?
    SL,UT
    88
    Have you taken any temp readings? What pinion are you using? I am running mine on 2s with a 28T pinion and I am getting temps around 150 after running for about 20-30 mins.
    You can drive my car, but there's a $500 deposit.
    9
    everything is stock except for the lipo, 150 degrees is pretty hot no?
    SL,UT
    88
    150 is hot to the touch but not more than the motor can handle. I have heard that 180-200 is the max temp you should ever let your motor get. I usually try to stay under 160. Anyone else heard of the max temperature for the Velineon 380 motor?
    Mar 2003
    Wherever the road takes me.
    37,138
    I always go by the 150 degree rule of thumb for all of my electronics. While it might be a little conservative for some motors and ESCs, it's better to be safe than sorry.
    SL,UT
    88
    Anyone seen an official word from Traxxas on this?
    Feb 2002
    4,984
    yes, the vxl motor has a little tag on it that says dont go over 200*
    traxxas says:
    Monitor temperature. When operating your model with two batteries, be careful to monitor the temperature of the speed control and motor to prevent overheating. Stop running your model and allow it to cool if the speed control's thermal overload protection activates or if the motor temperature exceeds 200 F. The Traxxas #4091 Temperature Gauge is a helpful accessory for monitoring motor temperature.
    this is their procedure for dual batteries, on this page, but the rule of 200* max still applies to a single battery
    http://traxxas.com/support/Dual-Batteries-116-Models
    also, on page 13 of the 1/16 revo manual, they again mention 200*
    http://traxxas.com/sites/default/fil...l_100205_0.pdf
    SL,UT
    88
    Thanks Jimbo. I knew I had seen that somewhere. I just couldn't remember where.
    CodsterTX - You should really invest in a temp gun if you don't already have one.
    Jul 2011
    Atascocita, Texas
    18
    I put fan on mine
    I put a fan on my motor, it still gets hot but not as much anymore. Plus, I think, it looks pretty good.
    11
    Where'd you get that fan and what does it plug in to?
    SL,UT
    88
    It can be found at any LHS. Or...
    http://www.rcplanet.com/Integy_Motor...c23141blue.htm
    It plugs directly into the receiver. Channels 3-5 should be empty.
    I got this last week and it has dropped my temps by about 10.
    Feb 2009
    Blfd,Wv
    325
    Heat sink with or with out fan and cut some holes in the body front and back to allow air to pass through. You really need a temp gun to measure as the finger method is just not reliable enough IMO. You could also try and drop back a tooth or two on the pinion.
    24
    I got the traxxas heat sink, w looking for the part#, but totally can't find it. Works very well with my 2s
    198
    my mini revo used to hit 216-250 degreese i still ran it and had no problems other then a couple melted parts around the motor. ran strong till the day i sold it telling the guy what happend he dident even care.... once he saw it run!!!!
    NO U CANT DRIVE MY SUMMIT!
