    Jul 2004
    Evansville, IN
    305
    what engine parts are interchangeable?
    Thinking about upgrading the Tmaxx from the 2.5 to 3.3. So it looks like the interchangeable parts are:
    -Carb
    -clutch assembly
    -flywheel
    -carb pinch bolt
    -front/rear main bearings
    -air filter
    -backplate???
    i was thinking if i could get the other parts cheap enough then i could build her from scratch then add the stuff above. for example TowerHobbies wants $29 for a simple 3.3 block and ebay i can for $12. anything else to add?
    Been on here for a while but forgot my original username.
    11,970
    Not sure about the backplate. The others sound right. Look at the exploded views of both and compare/contrast. The most expensive parts are the sleeve and piston and I would recommend a new rod. You'll also need a cooling head. Adding it all up it may be better to buy a new complete 3.3 off eBay.
    Oct 2005
    19,245
    You can pick up a new 3.3 for $105.00 off of Ebay from one of the chop shops...
    Piston and sleeve = $40.00
    Conrod = $30.00
    Bearings = $25.00
    Cooling head = $30.00
    Your already out of pocket more than if you bought the engine new.
    All Lives Matter
    10
    The crank is also interchangeable. If your looking for a serious 3.3 send me a message. I can hook you up for reasonably cheap.
    Oct 2005
    19,245
    Quote Originally Posted by 3.3 tweaker View Post
    They fit but there are differences in them. I would not put a 2.5 crank into a 3.3... But the opposite has been done and it seems to be good on the 2.5 engines.
    All Lives Matter
    10
    The bore size is smaller for the 2.5 that's it. It wouldn't be a powerhouse but is interchangeable that's all
